tires/wheel size - JeepForum.com
post #1 of 10 Old 03-10-2006, 07:28 AM Thread Starter
boosteddsm
tires/wheel size
I have an 84 CJ7 w/a 2.5" susp lift, 1" body, 6" flares. Will 33's fit under that? Currently I have 32's on the stock wheels. If 33's will fit, what width wheel to get? And get 33 x what tires? Thanks guys!
84 CJ7 - 258/T5/D300
92 Eagle Talon TSi AWD - 11.6@125
94 F250 4x4/460ci
01 Lexus GS430
boosteddsm is offline
post #2 of 10 Old 03-10-2006, 08:19 AM
Rockram1
We really need more info.
1. Is it a daily driver?
2. What kind of wheeling?
3. What engine?
4. What gearing?
5. What are future plans?
6. What kind of tires?
I ask these questions as they will affect the answer. I have 2 Jeeps.
80 CJ5 this is going to be my pretty Jeep. (It's in the rebuild stage) I'm going with 258, T18, dana300, 35x12.5 SSR's, 4.56 gears, Detroit rear and true trac front, 4" suspension and a 1" body.
The other is my sig built for the tuff stuff.
With the questions above we can determine your wheeling style. As a daily driver I'd go with a 10.5. If I was looking for the COOL factor I'd go 12.5. If wheeling in sand I'd go with a flotation tire, but mud i'd go agressive.
As you can see there is so many different scenario's. However when the day is done. It's your Jeep do what makes you happy.
86 CJ7, 258, t18, D300, D44's 4.56's, Detroit front, Warn shafts and CTM joints, spool rear, SOA, SRS, waggy springs, 6 point cage, Warn winch, 38" Tsl, Allied beadlocks.
Rockram1 is offline
post #3 of 10 Old 03-10-2006, 11:34 AM Thread Starter
boosteddsm
3. What engine?
4. What gearing?
99% street duty. Drivetrain info in sig. Not sure what gears are in it, probably whatever they came stock w/, it has an M20 rear. Will probably just go w/BFG All Terrain's. I figured it's just an inch bigger than the ones I have on there now? I just wanted to know if they'd fit ok and what the common 33" tire width is for a daily driver and what width rim to get.
94 F250 4x4/460ci
01 Lexus GS430
post #4 of 10 Old 03-10-2006, 11:45 AM
Mudinyeri
Mudinyeri's Avatar
If you're mostly going to be on-road, your only real worry is whether the tires will rub on the frame or springs during hard turns. If you stick with the same width tire and same backspacing on your rim you should have no worries.
I really like my 33X10.5X15R BFG MT's - they may be a little more aggressive than you want for a primarily street-driven rig. Take a look at the AT's in the same size.
Great minds discuss ideas; Average minds discuss events; Small minds discuss people.
Eleanor Roosevelt
Mudinyeri is offline
post #5 of 10 Old 03-10-2006, 11:52 AM
Xrossed
Xrossed's Avatar
This may help
I use the following as a daily driver in the summer ( down backroads to work)
and it can get mean and nasty on command...
4" pro-comp, 1" shackle lift, 35x14.5" super swamper tsl's
Xrossed is offline
post #6 of 10 Old 03-10-2006, 01:02 PM Thread Starter
boosteddsm
Thanks for the input guys. I wasn't aware that they sold 33x10.50 tires. What I really need to know is what width wheel to get and what the stock wheel backspacing is. I got new 6" flares so I need a wheel/tire combo that'll stick out some so the thing won't look silly!
94 F250 4x4/460ci
01 Lexus GS430
post #7 of 10 Old 03-10-2006, 02:25 PM
jeepskate
I'd go with a standard 33x12.5 and mount them on some 15x8 - 15x9 wheels...backspacing will typically be in the 3" neighborhood on those. You can find your backspacing yourself by taking off a wheel (your spare?) and measuring.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #8 of 10 Old 03-10-2006, 02:48 PM
John Strenk
John Strenk's Avatar
1976 CJ5
In my opinion,
Since it's 99% Street Drive, if you deside to go with 12.5" section width, I would go with a 9" or 10" to keep the tread flat and wear evenly at a desent tire pressure. Maybe a 8" wide tire with a with a 10.5" section width tire.
Down side is offroad, the tire could rub on outer fender lip even though you have 6" flares. And when you air down for off road you could brake the bead easier.
The narrower 8" rim would be great off road but you will wear your tire out faster.
John Strenk is online now
post #9 of 10 Old 03-12-2006, 10:48 AM
81CJ7Renegade
81CJ7Renegade's Avatar
I never did any lift with my CJ7, had a 8"wide rim and a 4" backspacing. I had 31's on there with no problems so I do not see why 33's will be a problem. I lifted my jeep up 12 inches and put a spare 36x12.5x15's on the spare with 4 inch backspace and 8 inch wide rim. Now the other 4 tires are on 10x15's rims with 4" backspacing. The front wheels I had to adjust the steering stop about 1/2 inch to keep knobs from hitting the front springs. The rear wheels I have about 2 inch clearance fron the wheel well. I am good to go
81CJ7Renegade is offline
post #10 of 10 Old 03-13-2006, 06:43 AM
Rockram1
Trying to fill the 6" flares will be interesting. I'd go with the 33x12.5 BFG a/t on a 15x10 wheel. You'll have to post a pic when you get it finished.
Rockram1 is offline
33 x 12.50 R15 tires. What is my wheel size? HHICJ7 Jeep CJ Forum 6 10-07-2009 02:40 PM
wheel rim size vs. tire size... hex Jeep CJ Forum 2 03-11-2009 09:10 AM
Wheel size on a CJ7 Jimthejeepman1 Jeep CJ Forum 4 11-23-2007 10:43 PM
What wheel size and backspacing for tires?? KSToyz Jeep CJ Forum 7 11-01-2007 12:58 PM
Wheel size St.Patrick Jeep CJ Forum 10 10-26-2007 01:21 PM
