Tired of the cold! Help - JeepForum.com
post #1 of 14 Old 04-18-2013, 08:08 PM Thread Starter
Toad1987
1983 CJ7
Well i'm tied of the snow and cold and the wishing the heater was better. What have you all done for heat? I'm tired of having to pull over every five or so miles and bang the ice off of the wipers or let my side windows clear on the inside. I've done the blazer blower motor upgrade but it still just isn't quite enough. You can either keep your feet warm or the window half way clean, not both. Has anyone tried this? http://http://www.heatercraft.com/je...der-dash-vent/
How did you mount it and does it work well?
Toad1987 is offline
post #2 of 14 Old 04-18-2013, 09:06 PM
texasimport
1978 CJ5
GM pm102 blower motor upgrade, moves more air, but rarely use high. In winter I cover the cowl vent intake and adjust the inner vent door so when I pull the vent knob out it opens the inner vent more early than normal, summer setting. The heater now draws air from inside and gets and keeps it warmer. I use my cj as a Dailey driver year round. Only gets truly nippy once it gets below 10.
78 304-CJ5
texasimport is offline
post #3 of 14 Old 04-18-2013, 09:15 PM
86cj74.2L
86cj74.2L's Avatar
Do you have a 195 degree thermostat?
Is the t-stat working properly? Some fail and run hot some fail and run cold.
86cj74.2L is offline
post #4 of 14 Old 04-18-2013, 09:56 PM Thread Starter
Toad1987
1983 CJ7
Thermostat is a 195 and its fine. I might try to find a way to open the inner flap and recirculate the inside air a little.
Sent from my DROID BIONIC using JeepForum
Toad1987 is offline
post #5 of 14 Old 04-18-2013, 11:29 PM
BagusJeep
1981 CJ7
Espar AIRTONIC Air Heater.
Basically a gasoline heater in the cab. You will not be cold again!!!!!!!!
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 14 Old 04-18-2013, 11:34 PM
HALOjmpr
You want what, when?
HALOjmpr's Avatar
1982 CJ7
Ol' Jimmy Buffet said it best, changes in latitude = changes in attitude It was downright hot here in FL today.
I hope you get it figured out .... I'll be asking for some of your cool air before long.
"It's not about how hard you can hit, it's about how hard you can get hit and keep moving forward!"
HALOjmpr is offline
post #7 of 14 Old 04-19-2013, 04:41 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Check to insure the heater box isn't filled with debris. Pine needles, leaves, and other debris can gather on top of the core, cutting air volume way down.
Check to insure the heater core isn't plugged. A plugged core will put out very little heat. Both hoses should be hot with the engine at operating temperatures.
Insure all your controls and cables are adjusted and working properly.
jeepdaddy2000 is offline
post #8 of 14 Old 04-19-2013, 04:47 AM
waterdowg
What is the temp of the heat blowing out? Perhaps you have a clogged heater core. My CJ get hot as @ell in the winter. Its stock with stock blower. I'm in NJ and last year we hit single digits. I had to take my coat off it was so hot.
waterdowg is offline
post #9 of 14 Old 04-19-2013, 10:57 AM
Davis77Cj
1977 CJ7
We have found the one AMC did right!
Only in America do you have the God given right to be loudly opinionated about something that you are completly ignorant of.
Davis77Cj is offline
post #10 of 14 Old 04-19-2013, 11:09 AM
waterdowg
I guess so
post #11 of 14 Old 04-19-2013, 11:49 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Mine was blowing 186*F on the outlet into the foot well.
John Strenk is offline
post #12 of 14 Old 04-19-2013, 11:53 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Make it two. My factor heater has no problems, even on the coldest days.
One tip I learned years ago as a life-long snow skier....if you can keep your windshield cold, and clean, snow won't stick to it while driving. You'll rarely even need your wipers, unless you stop.
The worst thing you can do is heat up your windshield with the defrosters in heavy snow. It just makes the snow stick to the glass worse, eventually clogging up the wipers, and creating a dangerous driving situation.
Matt
Matt1981CJ7 is offline
post #13 of 14 Old 04-19-2013, 12:18 PM Thread Starter
Toad1987
1983 CJ7
Problem is in the spring with freezing drizzle. The air out is hot there just isn't enough to keep the windows thawed. Most days when its that bad I drive my pickup. The crap the other day caught me by surprise. I drive it instead of my diesel pickup on the below zero days and 2-3 days a week normally. I was just wishing it would be a little better.
Toad1987 is offline
post #14 of 14 Old 04-19-2013, 12:27 PM
Matt1981CJ7
1981 CJ7
Yeah, freezing rain is a b!tch. Even my DD Tundra struggles with that crap.
Remember, you're dealing with 30-year old technology, here. Ideally, we could find replacement windshields with the heating element inside the glass, like newer vehicles have. But I haven't heard of anyone who sells them.
My advice....save your CJ for the bluebird days when you don't have to worry about it.
Matt
