Tire Wear Question? - JeepForum.com
post #1 of 3 Old 09-18-2009, 07:22 AM Thread Starter
Group_er
Tire Wear Question?
Hey guys, I did the chalk, tire wear test yesterday befor work, and found my fronts to be a bit to high. I lowerd them down from 26 to 25, But my rears: when heading in a strait line, are wearing more on the inside, than the outside. How do I correct this problum? More or less psi?
Thanks everyone!
Alan
Group_er is offline
post #2 of 3 Old 09-18-2009, 08:49 AM
Happy Joe
Inside vs. outside uneven wear on the front tires often indicates a front toe in or camber problem. (Googgle "home wheel alignment" for links that detail how to check the front camber, caster and toe-in).
Are you certain that the uneven pattern/wear is not a result of improper front toe in on tires that have been rotated from the front to the rear?
On the rear (especially with an AMC 20) it is a possible indicator of a bent axle housing. To check; level one tube of the axle housing and check the other tube if it is not also level then it is likely bent. You can also use an angle finder or level on the axle tubes and outside of the wheels to verify that both are at 90 degrees (vertical) to the axle center line.
In answer to your question; it is unlikely that tire pressure changes will affect this much, if at all.
Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway.
Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road.
Happy Joe is offline
post #3 of 3 Old 09-18-2009, 09:02 AM Thread Starter
Group_er
Thanks for the reply. Im running a completly rebuilt 9-inch, out of a 70's lincoln mark V. It has 1/4 inch thick tubes! I will be shocked if that is bent!! and bent the same on both sides!
As far as the caster/camber that you were talking about, DO you mean the front tire camber/caster will adjust the rear tire wear, on a strait line?
This was the rear tires I was talking about!
Group_er is offline
ALWAYS wear your Seatbelt! Even in your driveway. Mike Romain Jeep CJ Forum 68 12-18-2009 04:43 AM
How do I check for ball joint wear? 243 Jeep CJ Forum 6 11-17-2009 07:56 PM
Can just one cam lobe wear out? CRD508 Jeep CJ Forum 17 05-31-2009 03:12 PM
Uneven tire wear 6leafclover Jeep CJ Forum 2 02-22-2009 12:11 AM
PLEASE:Wear your saftey glasses Goody1231979 Jeep CJ Forum 15 10-24-2008 05:01 PM
