Tire sizes - JeepForum.com
post #1 of 11 Old 11-05-2013, 10:16 PM Thread Starter
jbiolchini
Tire sizes
Ive had my cj for about a year now on 31" and im needing to get some new tires. I dont have the money for a lift but i would like to run 33" if i get a 1" or 2" body lift would this work? Its all stock
jbiolchini is offline
post #2 of 11 Old 11-05-2013, 10:23 PM
Spieg8
1984 CJ8
What model/year CJ are you working on? Generally speaking, I wouldn't use more than a 1" body lift.
Spieg8 is offline
post #3 of 11 Old 11-05-2013, 10:25 PM Thread Starter
jbiolchini
1984. So that would work then?
post #4 of 11 Old 11-05-2013, 10:33 PM
BagusJeep
1981 CJ7
jbiol, if you fill in your Profile you will get more precisely wrong answers to your qustions!!!!
What size tyres would work for you will depend on the engine, transmission and axle ratios and what you intend to use it for.
In general 31" tyres are the largest that will work on a stock average 1984 CJ.
33" tyres will require some extra space but could work with the existing body if some more clearance between body and axle were achieved. A few members report rubbing issues even when lifted so you may not be out of the woods with just a small body lift. It is an inexpensive mod to fit 1" spacers with 33' tyres which will give you an additional 2" overall lift on the body, 1" under the diffs and better entry and departure angles. Whilst this is all good news it will be self defeating if your axle ratios are so puny that you will struggle to pull away.
Also be aware that 33" tyres may not actually be 33" in diameter. It is worth checking the physical size of what you are buying.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #5 of 11 Old 11-05-2013, 10:35 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
33"s are likely to rub with anything less than 3" of lift.
A 1" body lift won't even come close to clearing.
Matt
Matt1981CJ7 is offline
post #6 of 11 Old 11-05-2013, 10:45 PM Thread Starter
jbiolchini
Guess im stickn with the smaller tires...but thank you!
post #7 of 11 Old 11-06-2013, 07:33 AM
WindKnot
1977 CJ7
Good choice. Now fill out what you know about your Jeep on your profile. As you learn more, add more. But that information is important for an educated answer.
Nothing wrong with 31s.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #8 of 11 Old 11-06-2013, 04:39 PM
mvbrady
33 inchers will fit with a 2" body lift...and they will look alot better than those 31's...JMO
they will most likely rub if you take her to the dirt....on the street should be fine.
mvbrady is offline
post #9 of 11 Old 11-06-2013, 08:36 PM
Spieg8
1984 CJ8
Not necessarily, with the right body modifications, I've seen 35s fit fine with bone stock suspension. Put a competition cut on the rear quarters and some quality tube fenders on the front, and 33s will fit easy (no body lift required).
That's why I asked for more details. Don't want to make assumptions about what the OP has or wants.
Spieg8 is offline
post #10 of 11 Old 11-07-2013, 02:06 AM
Matt1981CJ7
1981 CJ7
I was assuming the OP didn't want to hack up his tub.
Matt
post #11 of 11 Old 11-07-2013, 06:48 AM Thread Starter
jbiolchini
Yeah im just looking to fit bigger tires without doing much as far as cutting up my tub
