Which tire size (and tire) for CJ-7 with 2.5" BDS lift? - Page 2 - JeepForum.com
post #16 of 23 Old 05-13-2011, 07:33 PM Thread Starter
danattherock
1981 CJ7
Thanks for the input man. I am tempted to just put a 4" lift on it and be done with it. But heard so many bad things over the years about handling after the fact, steering not matching up, drop arm?? something or another needed, etc... Seems from what little I know, a 2.5" kit will avoid many of these issues. Much to think about obviously.
-Dan
danattherock is offline
post #17 of 23 Old 05-14-2011, 12:57 AM
LordSul
1975 CJ5
4" lift, Transfer case lowering, long brake lines, drop pitman arm would solve much of the 4" lift problems.
LordSul is offline
post #18 of 23 Old 05-14-2011, 02:50 AM
CJ7crawler21
This is mine with a 2.5 rancho with 33/12.50/15
'84 CJ7 2.5" RC springs, xrc8 smittybuilt winch, Metalcloak overline, Metalcloak bumper/winch gaurd, D-rings front and back, Modded YJ family cage, RCI 15gallon Fuel cell, 33" Toyo MTRs
'69 DJ5 In progess.
CJ7crawler21 is offline
post #19 of 23 Old 05-14-2011, 03:58 AM
bandhmo2
I ran a 2.5 inch Procomp lift on my old CJ-7 with 33X9.50 BFG MT's, on stock wheels. Here are a few pictures. The skinny tires do not make the Jeep look big, but they give the ground clearance.
In mud with a hard layer within a foot of the surface they were great, in deep mud they left something to be desired as they do not offer much for flotation. In soft snow they were awesome, but on snow-machine trails with a hard packed surface and soft underneath, more flotation would have been very nice. For general Trail running very good, as good or better then a wider tire I would say.
No rubbing even stuffed at full lock. In general they were a good choice for me. I do not know if BFG still makes this size though.
bandhmo2 is offline
post #20 of 23 Old 05-14-2011, 07:08 PM Thread Starter
danattherock
1981 CJ7
Nice looking rides. Thanks for the pics.
Alaska? Spent two years in nome and kotz. Was in ANC Jan-feb. Lovely state.
The 2.5 lift and 33's are looking good. Still undecided on the spacers.
post #21 of 23 Old 05-14-2011, 07:29 PM
twinstickd20
1979 CJ7
Run the 33s if they rub, trim a little and if they still rub buy some tube fenders and open the rear wheelwells a little, the road manners will be alot better than if you run a 4in lift and I like the low cog look.
My Build Thread
twinstickd20 is offline
post #22 of 23 Old 05-10-2013, 10:26 AM
BradleyB17
1981 CJ7
I have a 2.5" rancho lift and a 1" body lift with Mickey Thompson Baja 33's and they rub when I turn all the way I'm going down to a 32"
BradleyB17 is offline
post #23 of 23 Old 05-10-2013, 05:51 PM
agear
I have 33"s and factory chrome wheels with a 2.5 bds lift but I also have a 1 inch body lift. It's my daily driver with no issues. The tires are a little puffy but you shouldn't blow a bead on the trail
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
lift and tire size help!!! OleBlueCJ7 Jeep CJ Forum 13 05-13-2011 09:32 AM
Max Tire Size - 84 CJ7 w/ 3" Lift cpistorius Jeep CJ Forum 12 03-14-2011 05:07 PM
SOA lift and tire size? davefreeman Jeep CJ Forum 21 03-27-2010 11:52 AM
How much lift for a particular tire size? supraman1990 Jeep CJ Forum 6 04-03-2007 08:28 PM
Post your lift size, tire size, necessary modifications, etc. Hillbillyd Jeep CJ Forum 7 06-06-2004 08:38 PM
