Which tire size (and tire) for CJ-7 with 2.5" BDS lift? - JeepForum.com
post #1 of 23 Old 05-12-2011, 11:13 PM Thread Starter
danattherock
1981 CJ7
I am getting the lift in the next week or two and need to pick out some tires. Trail riding would be the most off roading I would do for the most part. Hoping to get some 33's on my factory rims. Any suggestions on tires? Also, do you think 33's will fit? Thanks for any comment.
-Dan
danattherock is offline
post #2 of 23 Old 05-12-2011, 11:33 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
33's might rub a litte on rough trails.I have a 3" lift and run 32's with no problems any place I take her.
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #3 of 23 Old 05-12-2011, 11:36 PM
huntersdad
huntersdad's Avatar
1985 CJ8
You will probably have issues with the tires rubbing if you go with the 33s unless you install a body lift. I would run 32s at the most with a 2 1/2" suspension lift.
I like the Goodyear MT/Rs. I am on my second set (first of the new one with Kevlar).
S/f,
Tim Hamilton
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
huntersdad is offline
post #4 of 23 Old 05-12-2011, 11:36 PM
mojo_matic
1980 CJ5
I'm running 32" with 2.5" springs and shackle reversal.
mojo_matic is offline
post #5 of 23 Old 05-13-2011, 01:28 PM
MikeMCJ
1951 M-38
I run 32s with the BDS 2.5" and stock shackles (removed 1/2" HD shackles and it rides better) the only time it rubs is on the front of the leafs at full turn. I'd have no problem going to 33s (except that full turn, which I can fix easy enough)
MikeMCJ is offline
post #6 of 23 Old 05-13-2011, 02:49 PM
mvigo
mvigo's Avatar
I have a 2.5" Rubicon Express lift with a 1" body lift and 32" tires and have no issues whatsoever.
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #7 of 23 Old 05-13-2011, 06:06 PM
1911Tyler
1977 CJ5
I have the bds 2.5 and 31 goodyear mtr's. it looks good i love it.
1911Tyler is offline
post #8 of 23 Old 05-13-2011, 06:10 PM
1911Tyler
1977 CJ5
Here it is.
post #9 of 23 Old 05-13-2011, 07:30 PM Thread Starter
danattherock
1981 CJ7
Sweet looking rides.
Any opinion on wheel spacers? Wondering what 33" tires on spacers would look like along with the 2.5" BDS kit.
-Dan
post #10 of 23 Old 05-13-2011, 07:42 PM
my_304_cj7
1976 CJ7
I have a 2.5" superlift with wheel spacers and 33x12.50. I will probably go down in tire size the next go around for 2 reasons. 1. They look stuffed but I have never had any rubbing. 5+ months on the new tires 2. I would rather not use wheel spacers but the PO put them on and the spacers have a different lug pattern so unless I bought new rims I had to use the spacers. Here is a pic.
'76 CJ7 Quadra-Trac 304 2.5" superlift 1" body lift 33" DuraTrac's
2014 Grand Cherokee Altitude
my_304_cj7 is offline
post #11 of 23 Old 05-13-2011, 07:48 PM Thread Starter
danattherock
1981 CJ7
That looks awesome!! Very much like what I have in mind for my Jeep. Thanks for posting.
Any reason I am overlooking to not get spacers? I don't know jack about them. Seems like it may work out well with a 2.5" lift and 33" tires though.
-Dan
post #12 of 23 Old 05-13-2011, 07:55 PM
my_304_cj7
1976 CJ7
I am knew to this whole off road thing other than jerking around as a teenager but by putting the tires out farther you are increasing the stress put on the axle components. What said components are I do not know. Another reason I don't like the spacers is that the tires fling mud and debris into the cabin which could be fixed with wider flares but I like the look of the stock flares.
post #13 of 23 Old 05-13-2011, 08:00 PM
my_304_cj7
1976 CJ7
If you haven't done the lift yet you could add 1/2" lift shackles and while opinions may differ I doubt you would notice any wander with only a half inch but like I said mine has seen some two tracks and that is all it will ever see and I have had no rubbing.
post #14 of 23 Old 05-13-2011, 08:03 PM Thread Starter
danattherock
1981 CJ7
My muddin days are behind me so no big deal on the mud flinging. Got her when I was 15, babied her for the most part, now finally got some dough to spend and want to fix her up. I am 38, so it is a long time coming. Just fishing, trail riding, etc.. in my plans. As for the stress, makes sense, longer distance and all between wheels. Read lots about folks upgrading to one piece axles, something I would do as long as it didn't cost a fortune. I appreciate the insights. Just the kind of info I am in need of.
-Dan
post #15 of 23 Old 05-13-2011, 08:20 PM
1911Tyler
1977 CJ5
my white jeep in the picture above has 1.5 inch spacers to make it the same width as a wide track. only problem your going to have is if you put them on and try to put 33's on a 2.5 inch lift. when you put wheel spacers on it puts more leverage on the spring so in turn it will flex a little more. i know because i have them. and mine rubs 35's with a 6 inch lift. IMO you need to just do 4 inch if you want to run 33's if not they will look to tight and will rub. like someone else said no bigger then 32 on a 2.5 inch lift. As for spacers if you buy good ones they are fine if you buy some cheap junk off ebay thats what you will have. buy spidertrax or i bought Rugged ridge. good luck with it. it will look good with whatever you decide.
lift and tire size help!!! OleBlueCJ7 Jeep CJ Forum 13 05-13-2011 10:32 AM
Max Tire Size - 84 CJ7 w/ 3" Lift cpistorius Jeep CJ Forum 12 03-14-2011 06:07 PM
SOA lift and tire size? davefreeman Jeep CJ Forum 21 03-27-2010 12:52 PM
How much lift for a particular tire size? supraman1990 Jeep CJ Forum 6 04-03-2007 09:28 PM
Post your lift size, tire size, necessary modifications, etc. Hillbillyd Jeep CJ Forum 7 06-06-2004 09:38 PM
