Tire Size - JeepForum.com
post #1 of 17 Old 01-06-2014, 06:58 PM Thread Starter
556hjytt78
1980 CJ7
Tire Size
Hey guys. I installed the 4" rough country spring lift with no body lift. I was anticipating buying 33 X 12.50. Is that big enough for this amount of lift? The 30.5 x 9.50's on there now look like skateboard wheels. Any suggestions on whether 33's will look too small?
556hjytt78 is offline
post #2 of 17 Old 01-06-2014, 07:04 PM
UBERK
1976 CJ7
UBERK is offline
post #3 of 17 Old 01-06-2014, 07:17 PM Thread Starter
556hjytt78
1980 CJ7
Thanks for the thread. Tires are a big investment and I want to be sure I get the right size. So the springs wil settle slightly over time?
post #4 of 17 Old 01-06-2014, 07:23 PM
UBERK
1976 CJ7
They should. I have 33's with my 4" lift and like the looks.
UBERK is offline
post #5 of 17 Old 01-06-2014, 07:54 PM
BlueRubiconrich
what are you running for gears? that will help you with tire size.
ex. if you are running 2.73's then no to the 33's I'd look at some gear to tire charts before you buy.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #6 of 17 Old 01-06-2014, 07:55 PM
BlueRubiconrich
Oh I see 3.08's, stick with a 31" tire.
post #7 of 17 Old 01-06-2014, 08:02 PM
LumpyGrits
With that auto. I would look into a R&P change to keep from burn'n up that tranny. IF you go with 33's.
4.10 would do you well
Plus save'n the 'box'.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #8 of 17 Old 01-06-2014, 08:07 PM
LumpyGrits
Yes.
LG
post #9 of 17 Old 01-06-2014, 08:10 PM Thread Starter
556hjytt78
1980 CJ7
Geesh, you guys are good. Yes, it's a tf727 with 3.08 gears. This is obviously not a daily driver. I must get higher ratio r&p's to run 33's?
post #10 of 17 Old 01-06-2014, 08:28 PM
LumpyGrits
Yes, to take the torque load off your tranny and better all around 'driveablity'.
FWIW: I have a 5 speed w'33's, and run 4:88 R&P.
BTW: Your front axle is a Dana 30, not 35. The 35 is a POS rear axle used on the Wrangler.
One last thing. Sure hope your run'n 1 piece axles in the rear mod 20 axle. If your not-Add a set of Mosers to the list.
http://www.moserengineering.com/axles.html
LG
post #11 of 17 Old 01-06-2014, 08:39 PM Thread Starter
556hjytt78
1980 CJ7
It's a work in progress. Yes, I plan to upgrade the amc20. A guy wants to trade tires for a lock rite and one price axles for the rear. But now I may be researching 4.10 or higher ring and pinions.
post #12 of 17 Old 01-06-2014, 08:49 PM
LumpyGrits
Moser is the ONLY axle worth a dang in the 20.
LG
post #13 of 17 Old 01-06-2014, 10:33 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
MY R-Country seems more like a 6"! I tried my bro's 33 12.50 BFG A/T's & they seemed small. W/a 360-T18 & 4.10s in an 86 D44, I went w/35s. My shackles are .375" longer. Definitely change your gears....or a "safe" 50HP nitrous shot. Either way, w/o gears, bye-bye tranny
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #14 of 17 Old 01-07-2014, 09:28 AM Thread Starter
556hjytt78
1980 CJ7
I know we have different trannys, but how are the 4.88's at highway speed @55? Thats as fast as I plan on driving it. Afraid 5.13's might make it unstreetable. Trails are about an hour away at 55 mph max. Thats the most highway driving it will see.
post #15 of 17 Old 01-07-2014, 09:51 AM
strvger01
1966 CJ5
5.38's in my old m170 did fine at 55-60 mph. it was my daily driver for 2 years. it had 32" tires and a saturn od, and a swapped in scout 196ci 4 banger.
4.88 should do you well and for the distance you're going and 5.13's wouldn't be bad either, imho.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
