Tips on installing water temperature gauge - Page 2 - JeepForum.com
post #16 of 21 Old 10-11-2011, 10:00 PM
BagusJeep
1981 CJ7
The S post connects to that purple with tracer wire back to the sensor.
The + terminal is a +ve feed. As John Strenk pointed out it could go to the back of the speedo housing and join on to the red wire that used to feed the temperature and fuel gauges.
The other terminal surely must say - but it looks like +. this is a ground, depends on how your instrument panel is being grounded. If just through the metal of the panel etc it is will be uneliable. You may debate how to ground all your instruments but look at how the other gauges are grounded.
That black wire from the bulb also goes to ground.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #17 of 21 Old 10-11-2011, 11:57 PM
82JeepCJ7
1982 CJ7
Usually the gauge lights are powered by an orange wire. Look at a few other gauges to see where they get their power for the lights. It should vary in voltage when you turn the headlight switch left and right.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #18 of 21 Old 10-12-2011, 08:06 AM
John Strenk
John Strenk's Avatar
1976 CJ5
This is exactly right.
Looks like the Meter can be used on either + ground or - ground vehicals.
Looks simple enough to attach the black wire to the - post and then run a wire from the - post to a ground screw on the dash. Either make your own grounding point with a self tapping screw or the speedo mounting bolt on the back of the dash.
Run the + post to the "I" terminal on the back of the fuel gauge like Bagusjeep mentions.
Run the red wire on the light to some orange wire on the back of the dash like 82JeepCJ7 says
First time I ever saw a gauge with metric and English markings like that though.
John Strenk is offline
post #19 of 21 Old 10-12-2011, 08:29 AM
rickscj7boom
thanks guys for all your help, i will try this after i get outta work this evening.. we have perfect jeepn' weather down here in the imperial valley and i hate to see my jeep stuck in the garage.. i will post an update as soon as i connect this gauge..
good day amigos
rickscj7boom is offline
post #20 of 21 Old 02-02-2012, 02:01 PM
wglikes
Where did you purchase the temp gauge you show in the picture?
Thanks
wglikes is offline
post #21 of 21 Old 02-02-2012, 02:52 PM
turbogus
1978 CJ5
If you're going into the temp gauge anyway, if you've got the flow you may consider a wide sweep gauge;
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
autometer , gauge , overflow , overheat , overheating , thermostat housing , water temp , water tempurature
Temperature sensor/gauge wiring cer Jeep CJ Forum 6 08-26-2010 09:30 PM
Temperature Gauge gone INSANE!!! CJ8Extreme Jeep CJ Forum 1 10-08-2009 03:11 AM
oil temperature gauge silverbullit Jeep CJ Forum 12 08-17-2009 12:13 AM
86 CJ7 Temperature Gauge Wiring nokmoutjon Jeep CJ Forum 2 07-06-2008 06:48 PM
temperature gauge thenubsterman Jeep CJ Forum 3 07-17-2005 09:23 PM
