Tin ID tag on transfer case - JeepForum.com
post #1 of 10 Old 07-13-2009, 08:38 PM Thread Starter
Roadymi
1982 CJ7
What does it tell me? #'s are 300596-130 5359089
It is mounted behind a 3 speed and 258. The TC is too crusted in crud to get any casting #'s from.
Roadymi is offline
post #2 of 10 Old 07-13-2009, 09:58 PM
jackstercj8
1984 CJ8
look here at novak to id it, http://www.novak-adapt.com/catalog/t...components.htm goodluck
jackstercj8 is offline
post #3 of 10 Old 07-14-2009, 05:28 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
or we could just tell you that it is a 300 (hence the first numbers) you have a 2.56:1 low gear (unless modified), and since it is from an 82 it is the easier to find speedo geared long tail shaft. Everything else i believe is irrevellant.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #4 of 10 Old 07-14-2009, 07:16 PM
bleoh
I thought 3sp's had the Dana 20 behind them (assuming it is a manual and not an auto).
bleoh is offline
post #5 of 10 Old 07-14-2009, 07:36 PM Thread Starter
Roadymi
1982 CJ7
It is a 3 speed manual. And that is what I have been told, that a 3 speed manual should be attached to a dana 20. I would really like to get a clear idea of what I have to work with. I'm a big guy (6'5" 370 lbs) and it is a nightmare trying to get up into look for case #'s with everything covered in grime and that dasterdly huge skid plate in the way.
I am pretty sure the tub is an 82, chassis not so much as it has NT axles. I bought it on a repo auction so getting info from PO is out.
Roadymi is offline
post #6 of 10 Old 07-15-2009, 12:28 AM
Nickmil
Dana 300 was never used behind a 3 speed. If you can post pics that would be a big help. Behind a 3 speed if a centered rear output most likely a 20 unless the transmission is from a '71 or older CJ in which case it would be an 18 with an offset to the passenger side rear output. By the way, Dana 300's had a 2.62-1 low range.
'59 CJ-5, '59 CJ-6, '68 CJ-5, Bone stock '57 CJ-5, a couple of XJ Cherokees
Nickmil is offline
post #7 of 10 Old 07-15-2009, 05:27 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Yes both my Dana 300 and Dana 20 both had the tag that starts with 300. Confusing. Fastest way to tell is the mount or oil pan on the t-case. The 330 has a flat pan and round mount to tranny and the 20 has a deep pan and a "Texas" shaped mount to the tranny.
John Strenk is offline
post #8 of 10 Old 07-15-2009, 07:43 AM
Redmanchew
Redmanchew's Avatar
1982 CJ7
I was figuring since he posted it as an 82 someone had mated a 176 to a 300...but the tub swap and narrow axles... well as paul harvey says, now you know the rest of the story.
sorry for the mis-info!
post #9 of 10 Old 07-15-2009, 09:38 AM
CSP
Another easy way to tell a 20 from a 300 is with a magnet.
The rear output cone/housing on a Dana 20 is cast steel and a magnet will stick to it. The Dana 300 rear output housing is aluminum and a magnet will not stick to it.
Grime removal will be required, but at least it's minimal.
CSP is offline
post #10 of 10 Old 07-15-2009, 09:41 AM
attworth
1979 CJ7
Pictures' worth a thousand words.
With it being a repo, later model tub on NT axles, no real telling what it is other than assumption. My assumption is that it's a Dana 20.
attworth is offline
Transfer case help bobeaser Jeep CJ Forum 2 03-12-2009 05:02 AM
transfer case oil phil77 Jeep CJ Forum 2 07-08-2007 11:20 AM
transfer case phil77 Jeep CJ Forum 4 06-24-2007 08:36 PM
84 CJ7 Transfer Case ?? onesourcemike Jeep CJ Forum 1 05-15-2006 05:31 PM
transfer case? redcj576 Jeep CJ Forum 3 11-19-2005 10:48 AM
