Timing Set Replacement - JeepForum.com
post #1 of 4 Old 07-10-2011, 09:01 AM Thread Starter
adman02
1979 CJ7
Chilton manual says I need to use two special tools (j-22248 and j-9163) to install the oil seal on the timing cover. Is that true? Anything I can use in place of them?
adman02 is offline
post #2 of 4 Old 07-10-2011, 11:04 AM
Bubba Ray
Are the 232 and the 258 the same?
Bubba Ray is offline
post #3 of 4 Old 07-10-2011, 11:37 AM
MoC
You can get a piece of PVC pipe that fits in the recessed area of the oil seal and set it in place that way. If your careful you can also just tap it in place with a rubber mallet and usually not damage the seal.
MoC is offline
post #4 of 4 Old 07-10-2011, 12:44 PM Thread Starter
adman02
1979 CJ7
Same block and bore. Other differences noted here:
http://www.amcyclopedia.org/node/2259
From what I understand, parts are mostly interchangeable.
adman02 is offline
Timing chain cover seal replacement 80HouLaredo Jeep CJ Forum 3 03-23-2012 06:38 PM
76 304 timing chain replacement help needed urbikesucks Jeep CJ Forum 3 06-18-2011 11:24 AM
AMC 360 Timing Chain replacement JKM3134 Jeep CJ Forum 2 11-01-2009 08:15 PM
Timing chain replacement help DT5150 Jeep CJ Forum 7 05-26-2008 08:37 PM
Timing cover replacement info needed BIGM Jeep CJ Forum 7 08-16-2007 06:50 PM
