Timing Question... - JeepForum.com
post #1 of 10 Old 06-27-2009, 06:43 PM Thread Starter
poppatello
Timing Question...
Well, I just bought my timing light and about to do the nutter by-pass. I wanted to check and see where the timing was currently at before I did the by-pass. The timing is all over the place. It moves from 15 to about 21 . Is that normal for it to move like that during idle? Will the nutter by-pass take care of this part as well or do I have another problem internally? The motor is a 150 but only has 33,000 on it.
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
post #2 of 10 Old 06-27-2009, 06:47 PM
berserker
If your Jeep doesn't idle well, that fluctuation in timing is typical. I'm not sure if it will help, but you might try disconnecting your vacuum advance hose from the distributor (with the engine off), then fire it up and check the timing. Make sure you plug the vacuum line you when you disconnect it from the distributor.
Ignorance can be fixed, but stupidity is forever.
berserker is offline
post #3 of 10 Old 06-27-2009, 06:53 PM
FLBOY
YEP, Do that first.Then let it come to a full idle.
It,s better to be stuck , Than to have chickened out and went home
FLBOY is offline
post #4 of 10 Old 06-27-2009, 06:58 PM Thread Starter
poppatello
I did that, but only plugged it at the carb, do I have to plug the distributor too?
Paved Roads
post #5 of 10 Old 06-27-2009, 07:04 PM Thread Starter
poppatello
well I just plugged the distributor hose just for the hell of it and no change. My concern is if I do the nutter by-pass is how will I time it to 8 degrees?
Paved Roads
post #6 of 10 Old 06-27-2009, 08:07 PM
berserker
You might try and set your idle a little higher--just enough to smooth it out.
post #7 of 10 Old 06-27-2009, 08:10 PM Thread Starter
poppatello
well, I proceeded to do the nutter by-pass and while I was laying the new complete wires from ignition module to distributor, I found three open vacuum lines that run to the vacuum switches on the back fire wall! I would assume this would be the culprit of my timing been erratic...
Paved Roads
post #8 of 10 Old 06-27-2009, 08:30 PM
berserker
Only 3?
post #9 of 10 Old 06-28-2009, 08:04 AM Thread Starter
poppatello
Only 3?
well I replaced the carb like two summers ago and thought that I had removed or plugged all the lines that were no longer in used. I guess I forgot a couple. That could explain my low mpg huh?
Paved Roads
post #10 of 10 Old 06-28-2009, 12:35 PM
berserker
It happens--usually it costs a bunch of money in parts you didn't need to figure out a vacuum hose was off.
Timing question & adjusting carb question. jatepper Jeep CJ Forum 8 02-22-2009 09:29 PM
AMC 360 Timing Question cwajciec Jeep CJ Forum 6 10-28-2008 08:52 AM
timing question Fuzz21 Jeep CJ Forum 10 10-04-2006 02:10 PM
timing question sude thug cj7 Jeep CJ Forum 3 03-28-2005 07:27 AM
Another Timing Question ravinhuxley Jeep CJ Forum 1 04-29-2004 02:56 PM
