Timing on L-134 engine - JeepForum.com
post #1 of 18 Old 10-15-2011, 11:04 PM Thread Starter
brad31021
1947 CJ2A
I went of the deep end and sold my 97 TJ and banked the money but spent a little on a project Flat Fender. Currently just trying to get it to run before tearing down and rebuilding. It turns over but spits fire out the carb. I suspect the timing is of but can not find what the #1 plug should be on the distributer. Based on the piston position on #1 piston the rotor is firing after or at DTC. Any advice on setting the timing corrrectly would be greatly appreciated. I can not find any markings on the pully or on the fly wheel. It is a L-134 engine.
Please note the blue coil wire is between the number 4 plug post and the number 3 plug post I think. My buddy states his clips for the distributor is straight up and down and not in the same position as mine.
brad31021 is offline
post #2 of 18 Old 10-16-2011, 12:47 AM
Mickey_D
I looked all through the Willys shop manual and the only thing I got was where the timing marks are. The description they say on how to set the distributor timing is to get the #1 piston TDC and align the #1 spark plug on the cap with the rotor.
The manual says ignition timing is 5*BTDC. Can't for the life of me find the firing order and it's too dark outside for me to see right now.
Here's a pic of the timing mark:
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #3 of 18 Old 10-16-2011, 01:16 AM Thread Starter
brad31021
1947 CJ2A
Thanks, that is about what I have what I have been reading. Send some picks of what your wiring is if you get a chance tomorrow.
TKS
post #4 of 18 Old 10-16-2011, 03:03 AM
ralf
1947 CJ2A
the firing order is cast onto most heads. A search on the CJ2A forum will answer most of your questions. Several good wiring diagrams are posted. Your dizzy angle is correct. You won't find timing marks on the pulley like the illustration, the marks are on the fly wheel. There should be a small hole above the starter to see the marks. Originally there was a swing away cover over the hole.
ralf is offline
post #5 of 18 Old 10-16-2011, 11:05 AM
Mickey_D
ralf, I just realized why my info was incorrect - I've got the F134, you guys are talking about the L134.
Sorry about that, Brad.
________________
#4
Mickey_D is offline
post #6 of 18 Old 10-16-2011, 12:56 PM Thread Starter
brad31021
1947 CJ2A
Thanks to both of you. What do you mean by dizzy angle Ralf?
post #7 of 18 Old 10-16-2011, 01:49 PM
ralf
1947 CJ2A
I misread your post. I meant that the angle of your distributor looks like it should. You cant' go by thr location of the cap clips because your distributor may not be clocked right and your flywheel could have been installed 180 degrees out. You need to search the CJ2A forum which addresses all of these issues. I am in the same boat as my new 6 volt dizzy (distributor) arrives tomorrow and I have to figure all of this out. Begin by finding top dead center for no. one cylinder. You can only do this by a finger over the plug hole to find the compression stroke when it blows your finger off the hole when you turn the engine over by hand. At that point the timing marks will show through the small peep hoe. But, during the no. one piston exhaust stroke the timing marks will also be in the peep hole..
ralf is offline
post #8 of 18 Old 10-16-2011, 01:55 PM Thread Starter
brad31021
1947 CJ2A
I read that as well, looks like I will have to invite my buddy over to turn engine. Hard to turn with one hand and an old loose fan belt. :-) Good luck with yours.
post #9 of 18 Old 10-16-2011, 02:56 PM
ralf
1947 CJ2A
I use a 3/4 drive ratchet with an 1 3/8" socket to turn over the engine.
ralf is offline
post #10 of 18 Old 10-16-2011, 03:56 PM
Mickey_D
Or get a starter "bump" switch. It's a thumb button in a hand held thing with two wires with alligator clips. One clip goes on the battery +, the other on the starter solenoid. You can then "bump" the starter with one hand (with the ignition off so now worries about it try to start on you) and use the other hand to feel for the compression stroke.
http://www.napaonline.com/Catalog/Ca...124_0006402985
________________
#4
Mickey_D is offline
post #11 of 18 Old 10-16-2011, 04:55 PM Thread Starter
brad31021
1947 CJ2A
Good ideas, will try both. Why did you go with 6 volt dizzy instead of converting to 12 volt?
post #12 of 18 Old 10-16-2011, 07:01 PM
molsenice
1964 CJ5
molsenice is offline
post #13 of 18 Old 10-16-2011, 07:04 PM
molsenice
1964 CJ5
post #14 of 18 Old 10-16-2011, 08:07 PM
ralf
1947 CJ2A
Why stay with 6 volts? Because I can, I guess. I did upgrade from 6 volt generator to 6 volt alternator. Mine is a 47 CJ2A build. I did put disk brakes on the front and 10" drums on the back.
ralf is offline
post #15 of 18 Old 10-16-2011, 10:05 PM
BagusJeep
1981 CJ7
If I am not mistaken the first pic has the firing order cast into the head: 2 4 3 1
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
Engine Timing help 4.2L 6cyl rcawrse Jeep CJ Forum 8 10-08-2009 12:26 PM
engine Timing 232cid My77cj5 Jeep CJ Forum 3 02-11-2007 04:21 PM
Timing a 4.2/4.0L Engine blk98grand Jeep CJ Forum 4 06-13-2006 04:06 AM
Timing off=engine damage? Dimension4 Jeep CJ Forum 21 09-26-2004 08:36 PM
engine timing difficulties Eddo Jeep CJ Forum 5 12-12-2003 06:27 PM
