#1 | |
Timing a jeep
Have never used a timing light before and was wondering if anyone has a link to or step by step intructions on how to time my jeep. It is the 258 and has the nutter bypass. I think the timing is off but want to check and make sure.
83 CJ7 AMC 360, nuttered & team rushed. Dana 44 rear geared & locked, Dana 30 front geared & locked Dana 300 T. Case 4" Tough Country Lift, 1" daystar body lift, 1/2" shackle 35x12.50x15 MT MTZ's on MT classic 2's, Besrk Bumpers, Genright Tube Fenders |
#2 |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
It is basic. Get a nice idle, unplug the vacuum line and block it (though if it is ported it shouldn't matter) and set it to purr the best. Mine likes between 8 and 9 BTDC, others vary. A vacuum gauge can help dial it in. Go for the highest manifold vacuum and back it ff about an inch of vacuum. That should be real close to the best purr... Mine won't ripple beer in a glass on top of the air filter.
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
#3 |
Mine likes 8 BTDC, too. In fact, the "discoverer" of the Nutter Bypass recomends setting the timing to 8 BTDC and then tweaking from there.
Anyone feel free to add/help out if I miss a step... Find the timing marks on the front of the engine. Driver side, next to the timing chain. ( I had to clean off the area and highlight the marks with a dremel). Let the engine warm up to operating temp and set the idle on your carb as to run the smoothest you can. Make sure the timing light is getting it's signal from the #1 spark plug wire, loosen the bolt holding the distributor and disconnect the vacuum advance from it. This works best with two people...carefully turn the distributor while aiming the timing light at the timing marks and set the timing to 8 BTDC. (The timing mark will be next to the #8.) You can then adjust up or down slightly and feel/listen for the jeep to run the smoothest. I found that I have to adjust the carb afterwards and then go back and re-adjust the timing. Hope this helps and good luck! Keith
'85 CJ-7 '02 KJ Limited |
#4 |
You really don't even need to use a timing light. I just put my distributor in lastnight and pretty much set my timing by ear. Move your distributor till it runs rough then move it back till you get the smoothest idol. Your idol should be 8 or 9 hd rpms in nutral. Also once you get it set to the best idol take it up the road for a test run pay attention to you throtle response you shouldn't have any hesitation. That how I did mine and it runs awsome. Also I did check it with my timing light afterwords and it was about 8 BTDC.
#5 |
Underground Jeeps
I also set my new 258 to 8 BTDC.. runs like a dream there.
Mike 1986 Jeep CJ7 (photos) Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work |
#6 |
Thanks guys will give it a go
#7 |
If by chance you get Spark Knock or 'ping' back it off about 2 degrees and try again.
I did mine by filling up with 87 Octane gas and advancing the timing until I could just detect pinging when I lugged the engine and then accelerated rapidly. Then I simply buy one grade higher octane fuel and consider it done! I checked it later with a timing light and it ended up being at 6 BTC.... Bruce |
#8 | |
Off Road Forever
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
