Timing cover install tool? Huh? - JeepForum.com
post #1 of 10 Old 02-27-2010, 07:19 PM Thread Starter
frodin1
1980 CJ7
going through the Chilton book to finish up my cam install today and it says you need to use a timing cover alignment tool. Ok, why? What is it and what does it accomplish? Has anybody besides Jeep service reps used one of these? do I have to? I haven't heard anyone mention one before? Please clue me in. Thanks
frodin1 is offline
post #2 of 10 Old 02-27-2010, 07:24 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
It helps to align the crank pulley seal. If you just throw it on, and if the seal isn't centered, you will have an oil leak from that seal.
Rick
Cutlass327 is offline
post #3 of 10 Old 02-27-2010, 08:19 PM Thread Starter
frodin1
1980 CJ7
Hmmm. ok. Is this something you have to use? Know one ever seems to mention this tool when posting?
frodin1 is offline
post #4 of 10 Old 02-27-2010, 10:23 PM
scottymac62
1979 CJ7
If you just take your time, but a little oil on your new seal to lube it up, you can put it on without an alignment tool just fine. That how I installed mine. No problems', no leaks.
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #5 of 10 Old 02-27-2010, 10:29 PM
-AC-
1977 CJ5
I did my 304 last year (new distributor drive gear - and NO, before anyone asks, It didn't have the HEI in it at the time) with no special tools and it went fine. No leaks. The one bummer is that my fancy Fel-Pro gasket set had everything I needed, but the rubber seal between the front of the oil pan and the bottom edge of the timing cover was too short. So, you might want to make sure you get the right one. Other than that, it was a straight-forward job.
"Damn Everything But The Circus..." e.e.c.
-AC- is offline
post #6 of 10 Old 02-27-2010, 10:37 PM
mcmud
1983 CJ8
I use a partial install of the damper to align the cover and then pull it once more to tighten the one inaccessible bolt.
mcmud is offline
post #7 of 10 Old 02-28-2010, 04:06 AM
Patter
1981 CJ5
X2. Just use the damper. Pull down evenly, and you will be fine.
Patter is offline
post #8 of 10 Old 02-28-2010, 05:43 AM
243
1978 FSJ Cherokee
^^^ that is what I did too, works fine.
Dave's 78 Build
243 is offline
post #9 of 10 Old 02-28-2010, 05:57 AM
Mike Romain
I also do the same, put the balancer on twice.
Mike
Mike Romain is offline
post #10 of 10 Old 02-28-2010, 09:45 AM Thread Starter
frodin1
1980 CJ7
That's what I was thinking. Thanks
frodin1 is offline
timing cover removal Bill Ruppert Jeep CJ Forum 22 03-30-2010 10:56 AM
timing cover jkeating Jeep CJ Forum 5 11-30-2009 05:41 PM
304 Timing Cover Issue valjeep Jeep CJ Forum 4 09-01-2007 08:43 AM
258 Timing cover problem kcr121 Jeep CJ Forum 8 01-01-2007 09:44 PM
Timing cover ?'s DirtyDave Jeep CJ Forum 5 01-29-2006 01:01 PM
