Timing chain replacement - JeepForum.com
post #1 of 3 Old 02-28-2012, 05:02 PM Thread Starter
Tigerpaw
1983 CJ8
Well I have everything off and the timing chains got a little to much slack, any sure fired no fail methods to placing the gears and chain where when I drop the dizzy this thing might crank again?
Lots of builds out there I'm trying to reduce search headaches?
Tigerpaw is offline
post #2 of 3 Old 02-28-2012, 08:26 PM
frankush
I would search a little. Lots of posts on timing chain replacement. Lots of little problems too. From oiling problems after replacement, warped covers, covers with dimples vs. no dimples, etc.
frankush is offline
post #3 of 3 Old 02-28-2012, 08:31 PM
texasdave
texasdave's Avatar
1980 CJ7
First off you will have to find top dead center on the number 1 cylinder. Your timing gears will have alignment marks on them a dot or circle to match up. Before you pull the distributor scribe an alignment mark and note where the button is pointing. You can use a screw driver to align the oil pump. You may or may not have to use a puller to remove the gears. Buy new gears and chain and lube them with motor oil. I lay mine out flat first ro get an idea of where the marks will be. If your jeep " jumped time" you could have some internal damage. The gears will have a keyway slot so you can't mess that up. Any maintenance manual Chilton's etc will usually have pictures and step by step instructions
texasdave is offline
dizzy , pictures , timing chain , timing chain replacement
Timing chain cover seal replacement 80HouLaredo Jeep CJ Forum 3 03-23-2012 05:38 PM
76 304 timing chain replacement help needed urbikesucks Jeep CJ Forum 3 06-18-2011 10:24 AM
AMC 360 Timing Chain replacement JKM3134 Jeep CJ Forum 2 11-01-2009 07:15 PM
Timing chain on 258 I6 dlloyd443 Jeep CJ Forum 2 01-24-2009 04:50 AM
Timing chain replacement help DT5150 Jeep CJ Forum 7 05-26-2008 07:37 PM
