Tilt wheel for CJ5 - JeepForum.com
post #1 of 10 Old 10-08-2006, 08:57 PM Thread Starter
ConleyTD
1980 CJ5
Tilt wheel for CJ5
I'm doing a full restore of a '80 CJ5 and I would like to replace the steering column with a tilt wheel. Is there any other GM product that will cross swap to my jeep? I'd rather just run to the junk yard than try to order something online.
____________________________
1980 CJ5 in many, many pieces...
304, Pro Comp 4" Lift, 33x12.50s
ConleyTD is offline
post #2 of 10 Old 10-09-2006, 02:37 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I used a mid 70s Camaro tilt column in my old CJ.
BESRK is offline
post #3 of 10 Old 10-09-2006, 03:11 PM
gtrpup2
I know that my father-in-law took his out of an older caddy at the junkyard.
gtrpup2 is offline
post #4 of 10 Old 10-09-2006, 06:12 PM
Mudslide
Mudslide's Avatar
1980 CJ7
A guy here helped me out a while back, but I have'nt had a chance to tackle this project yet. I installed some seats from a 97 Accord (they ride great) and they were a little taller so my legs have to squeeze between the seat and wheel. Anyway he used a column from a 86 S-10. He said the elect plugs should plug into a CJ7. You will need to grind off the bracket on the S-10 column. You may have to mix and match the shafts to get the correct length. Measure the CJ column before you tear it down. You can even use the Chevy dimmer switch in the new column if you want to dig through the harness. I have'nt done this myself, I just rember what he said. I may be able to help more if you have specific Q's.
80 CJ7 Laredo-351W, NP435, D300, D30/AMC20, TJ flares, 36" TSL's, 3"BL, spray in liner, tube bumpers, and KC's.
69 F150-Hot 302. Project street truck.
94 Land Cruiser-33" MTX's (my wife's)
03 GMC-DD work truck.
Time is fun when you're havin' flies.
Mudslide is offline
post #5 of 10 Old 10-09-2006, 10:17 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Why not just find another CJ tilt column? They can't be that hard to find.
Pacfanweb is offline
post #6 of 10 Old 10-10-2006, 07:32 AM Thread Starter
ConleyTD
1980 CJ5
I just Googled the part and found a ton of other people looking for a tilt wheel. I guess I'll take a stroll through the junkyard.
I found one person that put a 1988 column from a YJ in - got the dimmer off the floor.
Thanks for the posts guys!
ConleyTD is offline
post #7 of 10 Old 10-10-2006, 07:56 AM
Bockwinkle
your chances of finding a tilt column out of a CJ in a junkyard are about zero. If you happen to find a Jeep junkyard that has one they are not going to let it go cheap. I recently bought one off of Ebay for $115 which basically needs to be gone through completely.....so in the long run you are going to be right up there around $200 which you can buy a new one from Centech.
That being said if you can get one cheap out of a S-10 or caddy that will fit with minor mods then go for it and all the more power to you!
Bockwinkle is offline
post #8 of 10 Old 10-10-2006, 12:51 PM
h2oman
plenty of tilt cj columns
I've tried to get rid of them before, but I've got a few tilt cj columns sitting around. You can see pics here---www.dropshots.com/h2oman
Let me know if anyones' interested.
1957 willys wagon----shhhh, you can hear it rusting....
1969 POWER WAGON-318, 36" tires, 60 rear w/ lock, D40 front, 4 spd manual trans., 4.10 gears
1976 CJ 7, 360, auto w/ quadratrac
1978 cj-5-mated to a 94 wrangler in a strange experimen
1979 cj7, best $5000 jeep that $13,000 can buy
2006 POWER WAGON-'nuff said.'
h2oman is offline
post #9 of 10 Old 10-10-2006, 08:09 PM Thread Starter
ConleyTD
1980 CJ5
Thanks anyway h20man. I went to the junkyard today and picked up an S10 tilt.
_____________________________
'80 CJ5 frame-off project in pieces..
ConleyTD is offline
post #10 of 10 Old 10-11-2006, 07:12 AM
jeepmor
jeepmor's Avatar
Tilt Column
I dig tilt columns, but when I slapped my jeep on its side this summer, it broke my steering column at the tilt joint. I now have a straight column and am still waiting for a new windshield frame to arrive after receiving a bad one. There goes the warm weather wheeling I had time left to do.
jeepmor
jeepmor is offline
1977 CJ5 how to install tilt wheel Matusel3 Jeep CJ Forum 13 10-09-2014 07:11 AM
Best Tilt Wheel Fit For 74 Cj5? seabug32 Jeep CJ Forum 3 10-12-2009 07:52 PM
Tilt wheel jmna Jeep CJ Forum 7 04-20-2009 09:39 PM
Tilt Wheel rosco96 Jeep CJ Forum 5 04-08-2008 04:34 PM
Tilt wheel help/how to... ThrlSkr Jeep CJ Forum 8 01-18-2007 03:09 PM
