tighting steering - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > tighting steering
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !
Unread 01-06-2009, 01:25 PM   #16
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Originally Posted by KBONSIG View Post
The wheel does not return to center on it's own - never did. I'm sure the box will impload soon as Mike R states above - I've driven about 100 miles since I adjusted it wrong - still working for now.
You can still go and adjust it right. If you pulled the drag link off or just unscrewed the drag link so you don't have to mess with the tie rod end part, then you can get an inch pound reading on the pitman. It would be best with no steering shaft attached too, but you could get close.
Then just tighten the adjuster plug in the steering shaft end and you should be good to go.
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
