Tie rod trouble - JeepForum.com
post #1 of 9 Old 06-29-2009, 09:05 PM Thread Starter
zillla
1930 VJ
Tie rod trouble
I noticed the other day that my tie rod is rather bent, just slightly.. I decided to remove it and have my machinist friend straighten it.. Problem is , even though it is unbolted and free, I cannot get it out.. Seems the springs are in the way and the threaded portion of the bal joints will not fully clear the holes.... Do I need to drop the spring enough to get it out?
1975 CJ5
zillla is offline
post #2 of 9 Old 06-29-2009, 09:27 PM
VACJ7
VACJ7's Avatar
Put jack stands under the frame and let the suspension droop.
VACJ7 is offline
post #3 of 9 Old 06-30-2009, 05:32 AM
mundy1
1976 CJ7
If you have it off replace it with a new one.
It being bent and rebent will severly weeken it and it could crack or break in half on the next big bump.
They aren't that expensive and failure could be real scary on the road let alone on the trail.
mundy1 is offline
post #4 of 9 Old 06-30-2009, 07:24 AM
78treehugger
1980 CJ7
Replace it. It has been weakened and WILL fail. They are cheap. Please be safe. And yes jack up the frame and let the suspension droop.
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage
It's easier to get forgiveness than permision.
Salad is what food eats!!!
78treehugger is offline
post #5 of 9 Old 06-30-2009, 08:43 AM
my73CJ
1973 CJ5
it you need a tie rod puller, they rent them at auto zone. just be careful when taking it off, when my finally let go it would have broken bone if it had hit my arm or leg, actually chipped the concrete in my garage floor
my73CJ is offline
post #6 of 9 Old 06-30-2009, 10:05 AM
Coiz
1979 CJ7
It sounds like he has them loose but they will not come out because of the interference between the knuckle and the spring. Lifting the frame to allow the suspension to droop would not provide enough room to get mine out.
The easiest way to get them out it to loosen both of the clamps and spin the rod until both tie-rods completely un-thread from the rod. Then they should be able to fall out with the rod not attached. I went with the Go-fer-it tie rod flip to keep that from happening again. It is easier to work on when you can pull them straight out of the top. I would also suggest replacing the bent rod.
Mike
Coiz is offline
post #7 of 9 Old 07-01-2009, 08:08 PM Thread Starter
zillla
1930 VJ
Thanx for the replies.. Yes I have then loose, but can't remove em.. I ordered a new tie rod assembly so I'll deal with it when the parts arrive.. Thanx for the replies, and now I know how to get em out and in..
zillla is offline
post #8 of 9 Old 07-07-2009, 09:34 PM Thread Starter
zillla
1930 VJ
Ok, update.. I recieved the new tie rod and ends today.. I was trying to unscrew the old tie rod off the ends with a pair of channel locks and the ends popped out. The new tie rod and ends went in easily, assembled.. Guess the bend in my tie rod was hangin me up.. Thanx again for all teh hep.
zillla is offline
post #9 of 9 Old 07-07-2009, 10:31 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
save the old one for a trail spare.
good luck
mb
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
cj5 trouble 8balls12 Jeep CJ Forum 4 10-15-2009 01:16 PM
Trouble when hot? BucketRider Jeep CJ Forum 2 04-16-2009 03:27 PM
trouble getting oil cap off jays83cj7 Jeep CJ Forum 2 01-07-2009 08:00 PM
Still having trouble DannibusX Jeep CJ Forum 7 01-21-2008 04:54 AM
hub trouble jeepster18_88 Jeep CJ Forum 1 02-01-2002 09:55 AM
