Quantcast Tie rod Kit / Worth it? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Tie rod Kit / Worth it?
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFG
Old 08-16-2008, 06:52 PM   #1
PEEH
Looking at buying this kit. Any thoughts?
http://www.ok4wd.com/index.php/catalog/product/rock_equipment_complete_tie_rod_flip_system/
PEEH
PEEH is offline   Reply With Quote
Old 08-16-2008, 07:02 PM   #2
Bard
My 2 cents...
For the money, not worth it. You can replace tierods for less than a 1/4 of that. Tierods need to be adjusted on occassion depending on your use. I do not have good success at keeping them straight or un bent. Just one thing after the other on a Jeep.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline   Reply With Quote
Old 08-16-2008, 07:11 PM   #3
bdmonist
WTF is that?
bdmonist's Avatar
I'd get the flip kit but go with some monster heavy duty tie rods if it were me
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
AMC 20 Write Up
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline   Reply With Quote
Old 08-16-2008, 07:58 PM   #4
turnabout
1974 CJ5
Looking at your profile I noticed you have a lift kit -- I found the flip to be helpful in keeping the springs from banging against tie rod due to the angle of my 3" lift. I used the reamer/sleeve kit and purchase the other stuff as I needed it. The flip will also help take the angle out of your drag link and lessen bump steer issues. I believe the flip kit is one of the best upgrades I have done for less than $100.00..............
The two best off-road vehicles in the world -- the Jeep CJ and rental cars.
turnabout is offline   Reply With Quote
Old 08-16-2008, 08:10 PM   #5
PEEH
Well, what do you suggest? I'm looking to get larger tie rod and drag link, and new ends. Most kits only have only the rods, and no ends.
I'm willing to go larger on the tie rod ends, I just have to get some tubes.
PEEH
Old 08-16-2008, 08:25 PM   #6
CJ Chet
I used their flip kit with a "Big Daddy" tie rod and drag link. Works great. The Big Daddy rods are monstrous, and my steering geometry is fantastic. Not even a hint of bumpsteer!
Beer is the answer - it doesn't matter what the question is!
'86 CJ7, 265 CI, DUI, TF999, Borla, Weber, 4" BDS Lift.
'04 TJ Sahara.
'00 TJ Sahara.
CJ Chet is offline   Reply With Quote
Old 08-16-2008, 08:36 PM   #7
Bigjeep65
1982 CJ7
Their description isn't very good, if it comes with the 1-1/8" tie rod and drag link (which I think it does), then I would say yes. Also didn't see any jam nuts in the picture - they would be needed if you went to a 1-1/8" rod.
Bigjeep65 is offline   Reply With Quote
Old 08-16-2008, 08:39 PM   #8
gojeepin
gojeepin's Avatar
1983 CJ7
I agree with Chet. The flip is fine but that kit is not the best you could do.
I did the flip and used Big Daddy tie rod and drag link too.
Unlike Chet, I went back to the original Pitman arm and got the lost turn radius back. I don't have bump steer issue either.
Vibration? Bump steer? Wandering? Read: Steering, suspension, and driveline basics. An article on how it works and where to look for problems.
83 CJ7, 4.1L 6cyl (4.0L bored .030" over), 35" tires, T-5 transmission, Dana 300 TC, Trussed AMC 20.
gojeepin is online now   Reply With Quote
Old 08-16-2008, 09:19 PM   #9
CJ Chet
I should also point out that mine has 1" lift shackles, so the flat Pittman arm wasn't an option for me. Most people with stock size shackles do use the flat arm!
'04 TJ Sahara.
'00 TJ Sahara.
Old 08-17-2008, 01:08 AM   #10
BAH07
1983 CJ7
For you guys that did the flip.. Did you get a kit or just get parts to do it?
Also CJ Chet what brand of ends are you using?
BAH07 is offline   Reply With Quote
Old 08-17-2008, 06:04 AM   #11
PEEH
Does the big daddy kit come with all the ends?* The tube on it is 1.25?* I think.* So,,,,Big Daddy kit is $159* Then the flip kit is $85, other ends are $60,* This equals $304.* Yes, I would love to buy tube and ends and make all this myself, but this one is already done.* The special tools come with it.* I know everyone here and on othe boeards rave about the flip kit.* This is something I am doing.* I just thought I might upgrade the tubes while I was at it.PEEH
Old 08-17-2008, 07:09 AM   #12
CJ Chet
I got the kit with just the inserts and reamer. As Peeh said above, Big Daddy rods come with ends.
'04 TJ Sahara.
'00 TJ Sahara.
Old 08-17-2008, 12:31 PM   #13
bdmonist
WTF is that?
bdmonist's Avatar
I went Big Daddy as well. I have 1/2" lift shackles, 4" sus lift and went back with the stock pitman arm, Geometry is very good and the steering is great. I got the inserts and reamer on the flip kit as well. There are many on here that will loan their reamer out for the cost of shipping, me included. That way the kit only cost you about 20 or $30 for just the inserts.
AMC 20 Write Up
Old 08-17-2008, 01:04 PM   #14
PEEH
So the big daddy kit comes with the four rod ends? It looks like only one in the pictures. If this is true, then this brings a new light on the subject.
PEEH
Old 08-17-2008, 02:22 PM   #15
bdmonist
WTF is that?
bdmonist's Avatar
PEEH
From memory, I think mine only came with one TRE. I ordered 3 more and replaced them all. I think the kit is set up to accept stock CJ TRE's, so they assume you can reuse your existin. I replaced all mine. I am very happy with the kit. You can save about $30 by ordering off ebay.
http://www.bigdaddyoffroad.com/product_info.php?cPath=21&products_id=67
AMC 20 Write Up
Glock Forum
