tie rod flip - Page 2 - JeepForum.com
post #16 of 19 Old 02-27-2013, 08:30 PM
WSS
WSS's Avatar
1972 CJ5
Originally Posted by JohnnyRotten View Post
I am seeing some people are having issues with the tie rods hitting after doing the flip on their Jeeps. I see M.O.R.E. sells a steering box mount hat is an 1 1/4" forward from stock will this solve the problem? Thank you.
What are the tie rods hitting?
WSS is offline
post #17 of 19 Old 02-27-2013, 08:31 PM
dg6772
I'm having mine done by a local guy who's done many. He says he can do it installed for less than M.O.R.E.Gotta do it! Lol
From Dave G. in Muskegon
dg6772 is offline
post #18 of 19 Old 02-27-2013, 08:44 PM
zbd74
1980 CJ7
I did the flip many years ago when running the D30, worked great for me till I blew the knuckle off, then I upgraded to a D44 & went Hi-steer 1ton setup
Went through OK4x4, At the time they supplied a tapered reamer also. Doesn't look as if they do now though, but you could ask
Slightly Modified '80 CJ7
zbd74 is offline
post #19 of 19 Old 02-27-2013, 08:49 PM
WSS
WSS's Avatar
1972 CJ5
If I ever need to change knuckles, I think that would be the rout I would go too. I think my driver side knuckle has a bend in the arm, it is slight so I am not sure if it is indeed tweaked or not. It may prove to be the excuse I need to do it though LOL.
WSS is offline
