Tie Rod Assembly? - JeepForum.com
post #1 of 7 Old 02-28-2011, 08:13 PM Thread Starter
cgi2099
Tie Rod Assembly?
Does anyone know if these two are the same part but with the one from quadratec you can replace both tie rod ends instead of the one from oreilly's where you can only replace one tie rod end and the other side is fixed?
Quadratec
Oreilly's Part Number: ds1070
Your gonna have to type the part number in on oreilly's because i can't seem to get the link to work.
cgi2099 is offline
post #2 of 7 Old 02-28-2011, 08:19 PM
gojeepin
1983 CJ7
Quadratec
Oreilly's
The O'Reilly link didn't work for me but I'm assuming the one from Quadratrac is a tie rod and the one from O'Reilly is a drag link.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #3 of 7 Old 02-28-2011, 08:30 PM Thread Starter
cgi2099
Sorry bout the link but i can't get it to work, i edited my post and put the part number so you can type in on oreillys website. I need this part from oreillys because oreillys doesn't sell it anymore they told me. I don't know why still have it on their site but who knows how they think.
cgi2099 is offline
post #4 of 7 Old 02-28-2011, 09:14 PM
gojeepin
1983 CJ7
They aren't the same. The one at O'Reilly's is a drag link and the one on Quadratec is a tie rod.
Here's a drag link assembly from Quadratec. http://www.quadratec.com/products/56117_01.htm
Which do you need?
gojeepin is offline
post #5 of 7 Old 02-28-2011, 09:23 PM Thread Starter
cgi2099
Yep i need the drag link, thank you very much, do you know if the drag link tie rod ends are replaceable?
cgi2099 is offline
post #6 of 7 Old 02-28-2011, 09:28 PM
gojeepin
1983 CJ7
For the OEM drag link, one side uses a tie rod end and the other is the link with the end permanently attached. It uses an adjuster sleeve to connect them and adjust the length.
Some heavy duty replacements, like the Big Daddy drag link, use tie rod ends on each end of the heavy duty rod. The rod itself is turned to adjust the length.
gojeepin is offline
post #7 of 7 Old 03-01-2011, 12:52 AM Thread Starter
cgi2099
okay thank you very much! Ill be getting the big daddy drag link!!
cgi2099 is offline
air filter assembly paraman72 Jeep CJ Forum 6 09-02-2010 05:36 AM
Hub and rotor assembly st3dnut Jeep CJ Forum 2 08-15-2010 09:35 PM
Horn Assembly DocThirst Jeep CJ Forum 7 08-11-2010 11:15 AM
401 oil pump Assembly franqui74az Jeep CJ Forum 2 05-29-2010 01:31 PM
Heater box assembly ?? dblock16 Jeep CJ Forum 5 03-15-2007 09:56 AM
