Quantcast Ticking sound up front comes and goes...DRIVING ME CRAZY - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Ticking sound up front comes and goes...DRIVING ME CRAZY
Old 04-05-2009, 08:42 PM   #1
neals80
1980 CJ7
Okay....I am getting a ticking sound that comes and goes when driving down the street....does not matter what speed...when you break it goes way..pretty sure it is the drivers side front....
So I jacked the entire jeep up and removed the front tires...with limited slip the driver side tire would not turn in 4wd....I spun the disc by hand and no ticking...I removed the break assembly and inspected and cleaned took the hub apart all good and all working fine....PLEASE HELP....If more details are needed I will try and get them to you
Neal Trombley
1980 CJ 7
SW FLORIDA
IF I WANTED A HUMMER I WOULD HAVE CALLED YOUR GIRLFRIEND!!
neals80 is offline   Reply With Quote
Old 04-05-2009, 08:56 PM   #2
26679cj5
make sure there's no gravel stuck in your tire
26679cj5 is offline   Reply With Quote
Old 04-05-2009, 09:13 PM   #3
neals80
1980 CJ7
Tires are clean....I thought the same thing....It is just weird it goes away when you apply breaks
Neal Trombley
1980 CJ 7
SW FLORIDA
Old 04-05-2009, 10:55 PM   #4
JeffMcBusa
1979 CJ7
I couldn't geet any help on mine when it did that but I narrowed the noise down to the drivers side exhaust manifold tapping against the firewall. It think it was partially due to one motor mount being shot. I replaced both motor mounts and it helped the situation, now it only occasionally taps the firewall. Gonna replace the 30 year old body mounts next. After that I am gonna have to dimple the fire wall. Mine has a 304 so this may not be the issue with yours. Can't hurt to look though. Mine was tapping on bumps and vibrations in the roadway. Gas and brake did not affect it.
JeffMcBusa is offline   Reply With Quote
Old 04-05-2009, 11:08 PM   #5
andy_mitch92
World turns under my Jeep
andy_mitch92's Avatar
1977 CJ7
It could also just be a leak out of your exhaust manifold. Mine goes away while not on the gas and you cant really hear it unless the motor is under load.
andy_mitch92 is offline   Reply With Quote
Old 04-06-2009, 04:32 AM   #6
JavaTee
1979 CJ5
I have the same noise. It's your brake pads. I've cut an aluminum can to match the back of the pad (as a spacer - for the caliper side) and the ticking went away......temporarily. It was gone for a while, and has come back. Have fun.
Later, T.J.
JavaTee is offline   Reply With Quote
Old 04-10-2009, 12:59 PM   #7
neals80
1980 CJ7
I left the break pad clip off.....
Neal Trombley
1980 CJ 7
SW FLORIDA
Old 04-10-2009, 01:34 PM   #8
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
You hear it all the time when you're on the gas? My 80 did that cause my kid didn't turn the hub all the way back to 4x2. it was about a mm or 2 away. Worth a look.
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline   Reply With Quote
Old 04-10-2009, 02:28 PM   #9
sgtbookie
1982 CJ5
Speedometer cable? Mine used to chirp and click up a storm. Try disconnecting it and see if it goes away.
- 1982 CJ5 -
AMC 258 TeamRushed, MC2100, T-176, Dana 300, Goodyear AT 31's, AMC AM Radio, SuperTop, Tuffy Stereo Console , Black Diamond AT Shocks , CJ Draw Bar, Herculiner
The secret to a jeep, especially a cj, is you can't panic. - Mike
sgtbookie is offline   Reply With Quote
Old 04-12-2009, 08:29 AM   #10
ConleyTD
1980 CJ5
Bump...
I have the EXACT same issue. Does anyone else have any other suggestions?
I'm thinking breaks too... A touch of the break and it goes away. I've got brand new breaks!
**1980 CJ5 Frame off resto - DONE!.**
Firefighters Jeep Club
ConleyTD is offline   Reply With Quote
Old 04-12-2009, 08:44 AM   #11
Mike Romain
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Umm.... The OP said he fixed it, he had left the spring clip off the brake pads....
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Old 04-12-2009, 11:04 AM   #12
ConleyTD
1980 CJ5
At that, my friends, is your Easter Sunday lesson in 'paying attention'!
I now return you to your regularly scheduled Jeep Forum already in progress (while I go check for a spring clip)
Glock Forum
