Quantcast Ticking from front axle - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Ticking from front axle
Great deals on Mickey Thompson Tires @ Jeephut.comOfficial Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFG
Old 11-03-2009, 01:03 PM   #1
TKFireman
TKFireman's Avatar
1980 CJ7
I just rebuilt my front axle, the NT dana 30 with 4.10's, lockright, all new seals and bearings. Now I have a ticking sound coming from front axle, it speeds up and slows down with the jeep, so it has to be something in the rotating assembly.
The ticking goes away as soon as any pressure is applied to the brake pedal, don't even have to apply enough pressure for the jeep to slow down to make the noise stop.
I reused the brake pads from before the rebuild, but they had a lot of life left on them, so I don't think it has to do with the pads themselves.
Any Ideas?
"If your gonna be dumb, you gotta be tough"
Build Thread
TKFireman is online now   Reply With Quote
Old 11-03-2009, 01:04 PM   #2
tfd07
sounds to me that the lockright is bypassing. is it doing it with the hubs off and in 2 wheel drive
tfd07 is offline   Reply With Quote
Old 11-03-2009, 01:13 PM   #3
TKFireman
TKFireman's Avatar
1980 CJ7
yes, forgot to mention that, 2WD, new mile marker supreme hubs unlocked, so axle shafts and drive shaft should not be turning...
Build Thread
Old 11-03-2009, 02:08 PM   #4
80cj
80cj's Avatar
1980 CJ5
Could be the disc brakes. Did you install the anti rattle clips?
80cj is online now   Reply With Quote
Old 11-03-2009, 02:16 PM   #5
TKFireman
TKFireman's Avatar
1980 CJ7
if your talking about the little spring clips that go on top of the bar that holds the caliper on, then yes I did, are there other clips?
Build Thread
Old 11-03-2009, 10:32 PM   #6
jeepdaddy2000
1971 CJ5
Might jack up the front end and wiggle/spin the wheels by hand. If you can make the noise that way you should be able to pinpoint the problem.
jeepdaddy2000 is offline   Reply With Quote
Old 11-03-2009, 11:09 PM   #7
80cj
80cj's Avatar
1980 CJ5
There are little spring steel clips (actually they're called anti-rattle springs) that keep the pads from rattling. I had a little problem with clicking from the front as you describe the first time I replaced the pads. Turns out that I had left the clips out.
Old 11-04-2009, 03:50 PM   #8
nicknoty
1983 CJ7
i have a clicking from my stock hubs after changing the front gears. when i release the hubs and go 2wd it clicks for a little while and goes away sounds the same simtins to me.
83 cj7, white/pearl w/ black trim - 99'ax-15/clocked dana 300 twin sticked - 4"RC lift - HD shackles - 33X10.5 bfg mt's on micky' T 15" classic 2s - HD tierod flipped - custom bumpers with d-rings - winch - flowmaster - obd1 efi swap - 4.6L strocker with com smooth idle cam. soon to be:
rear disc brakes,front and rear tube fender flares and better sliders, 3.0L mercedes turbo diesel power
nicknoty is offline   Reply With Quote
Old 11-04-2009, 04:08 PM   #9
Mike Romain
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Interesting, mine has large rod shaped spring clips going across the anchor plates from side to side to stop rattle.
I would be wanting to check those again if they are like mine, have had and seen them come unhooked or jammed during the install several times.
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Glock Forum
