Tick to tap, collapsed lifter... - JeepForum.com
post #1 of 8 Old 06-27-2013, 08:59 AM Thread Starter
jdhaas3
My 258 has had a small tick since I purchased it a while back. It has gotten a little louder since then. I just replaced the rocker arms and push rods but that didnt fix the problem so I am pretty sure it is a collapsed lifter. If I am going to be replacing lifters, I am going to just replace the cam while I am it apart. This is the one I am looking at getting from comp cam, just looking for opinions. I just want to get rid of my tapping, I dont want to do anything crazy with this jeep.
http://www.compperformancegroupstore...ode=CL68-231-4
jdhaas3 is offline
post #2 of 8 Old 06-27-2013, 05:59 PM
OldTexas
See if you can find a product called Hydra Valve Clean by Siloo. You may not even need to replace anything.
Paved roads, another example of government waste!
OldTexas is offline
post #3 of 8 Old 06-27-2013, 09:19 PM
Oily
My CJ also has a tick, and has had it since I got it. I think it is getting worse though it sounds the same as yesterday. If I compare it to what it sounded like when I got it I think I would say it is worse. Getting a little worse everyday makes it hard to tell.
That said, I have a good friend who is an ASE certified auto tech and has worked for some major dealerships. He and I looked into it (some disassembly) He thinks I have a piston wrist pin knocking and assure me it is not fatal. (The wrist pin connects the piston to the connecting rod which connects to the crankshaft.)
I hate that tick.
Oily is offline
post #4 of 8 Old 06-27-2013, 09:52 PM
LumpyGrits
Try a can of Restore. This stuff works!
What weight oil are you using now?
LG
LumpyGrits is offline
post #5 of 8 Old 06-27-2013, 10:52 PM
Dougyfreshh
Pour a half a quart of atf trans fluid in your oil run it for a few miles and change oil some times it will clean them up
Dougyfreshh is offline
post #6 of 8 Old 06-28-2013, 02:19 AM
80cj
80cj's Avatar
1980 CJ5
Marvel Mystery oil worked for me. Drain a quart from your crank case and add a quart of the stuff. Didn't take long for it to work for me.
80cj is online now
post #7 of 8 Old 06-28-2013, 07:51 AM
texas1al
Is the tick/tack only at startup or is it there once the engine's warmed up. If you're using a fram oil filter, I'd change that right away to a better quality filter like a Napa Gold (Wix) or a PureOne. Changing to a heavier oil like a 15W-40 might also help. Per the factory owner's manual, heavier weight oil like 40W or 50W is fine in warmer temps and for older engine's like our's, it generally helps all the time unless outside air temps are consistently below freezing. Also, might try a high-detergent oil like Rotella to clean things up. Might sound like a shortcut fix, but switching oil weights and filter works wonders at quieting valve train noise in the 258.
texas1al is offline
post #8 of 8 Old 06-28-2013, 08:02 AM
Oily
Originally Posted by texas1al View Post
Changing to a heavier oil like a 15W-40 might also help. Per the factory owner's manual, heavier weight oil like 40W or 50W is fine in warmer temps and for older engine's like our's.
Just a thought on this and my previous post. A wrist pin does not get normal engine oil lubrication. A heavier oil might help rule out a lifter tick/tap.
Oily is offline
