throw out bearing issue - JeepForum.com
post #1 of 9 Old 06-27-2013, 01:47 PM Thread Starter
war6191
1979 CJ7
Recently replaced entire clutch assembly (Napa) in my cj7. It shifts well, hooks up
Good and is quiet. I have maybe 1200 miles on this job and am noticing onset of lite chatter with involuntary movement at the throwout arm. If I loosen the settings for pedal free play according to the manual, the bearing sounds worse. Tighten linkage a bit and it lessens. I realize this means a bad bearing but why would it fail so soon? I will I'd assume, be replacing it but it isn't looked forward too and I do not want a repeat event. Any ideas?
79 cj7. 258 TBI. T 176 with D300
war6191 is offline
post #2 of 9 Old 06-27-2013, 03:07 PM
LumpyGrits
Did you replace the pilot bearing in the flywheel?
LG
LumpyGrits is offline
post #3 of 9 Old 06-27-2013, 03:23 PM
scrapman
LG
+1. When my pilot bearing dried out, it sounded like baby birds living in my clutch.
scrapman is offline
post #4 of 9 Old 06-27-2013, 03:34 PM
LumpyGrits
That is why I went with a roller bearing instead of the bushing
LG
post #5 of 9 Old 06-27-2013, 05:10 PM Thread Starter
war6191
1979 CJ7
Yes' new pilot brushing. I'm getting a throb like feel and movement at the throwout arm, like it isn't riding on the bearing evenly or something...then when pressure is applied to the bearing it quites down. I wonder if I fried it somehow, maybe had it set too tite
war6191 is offline
post #6 of 9 Old 06-27-2013, 05:24 PM
LumpyGrits
What is the pedal freeplay set at?
I keep mine at about 1 1/4 inches.
As the fricton plate wears. You lose the f'play.
LG
post #7 of 9 Old 06-27-2013, 06:12 PM
JeffreyCharles
1976 CJ5
Was the pressure plate torqued down properly and in sequence to prevent it from being (even just a bit) warped?
Jeffrey Charles
http://jeep.smallcraft.net/
JeffreyCharles is offline
post #8 of 9 Old 06-27-2013, 06:22 PM
Dougyfreshh
Are your inner and outer return springs for the clutch fork in good condition
Dougyfreshh is offline
post #9 of 9 Old 06-27-2013, 06:26 PM
LumpyGrits
Was the flywheel resurfaced for this new clutch?
CONFIRM..new pressure plate, new friction disc(you do have it in the correct way)and new T/O bearing. Is this correct?
LG
