Throttle cable and linkage help please - JeepForum.com
post #1 of 3 Old 02-28-2010, 12:41 AM Thread Starter
dizney4
I have a 83 CJ7 and have replaced the 4.2 with howell FI on the stock intake with a mid 90's 4.0 with the same howell FI on a clifford intake. My problem is the clifford intake does not have the mount for the stock linkage. So how do I get the throttle cable to hook up? If you have pictures that would be great. Thanks for any help anyone can be.
dizney4 is offline
post #2 of 3 Old 02-28-2010, 07:14 AM
CJ Chet
Forget the linkage and run the cable straight to it.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #3 of 3 Old 02-28-2010, 11:19 AM
-AC-
1977 CJ5
This may not be much help, but you aren't getting a ton of replies, so I thouht I'd throw it in. My 304 came with a Super-High Tech-Ultra Performance coat-hanger throttle "cable". The one I ordered from 4WD was model-correct, but too short. Luckily, they had the length of each year/model in the catalog, and so I got a bit smarter, measured how long it should be at closed-throttle, and was able to order one that works well. With any luck, maybe you can take a tape measure, see how long a cable you need, and find one that's close enough to offer full-closed and full-open on your TBI.
Just a thought...
"Damn Everything But The Circus..." e.e.c.
-AC- is offline
Need some throttle linkage help!! Mud_Gypsy86 Jeep CJ Forum 3 08-08-2009 09:06 PM
auto column shifter cable(linkage) twokids Jeep CJ Forum 6 02-21-2008 06:02 PM
Throttle Linkage alman Jeep CJ Forum 2 01-16-2007 08:57 AM
76' cj7 throttle linkage problem outdoors76 Jeep CJ Forum 5 05-09-2006 12:20 PM
Throttle Linkage help Jeep Daddy Jeep CJ Forum 1 06-07-2003 09:27 AM
