three speed connectors - JeepForum.com
post #1 of 6 Old 03-29-2012, 07:47 PM Thread Starter
warrior1670
What are these for? Got a three speed tranny (T150?) and a dana 20
2012-03-29_21-41-08_112.jpg   2012-03-29_21-40-50_763.jpg   2012-03-29_21-41-00_555.jpg
warrior1670 is offline
post #2 of 6 Old 03-29-2012, 08:25 PM
WindKnot
1977 CJ7
Right rear = reverse switch. Jeep Dana 20 transfer case didn't have a 4WD indicator light. If your Jeep is an '86, stock TC was a Dana 300 which did have an indicator.
Also, don't be surprised if the connectors don't match.
WindKnot is offline
post #3 of 6 Old 03-29-2012, 08:38 PM
Pathkiller
1974 CJ5
Orange wire with plug is a 4wd indicator light. I'm assuming this is in your 86 CJ7 and you've swapped an older drivetrain into it? If so the D20 has no provision for a 4wd light, so this wire won't be used at all.
Pathkiller is offline
post #4 of 6 Old 03-30-2012, 06:18 AM Thread Starter
warrior1670
Thanks, the Jeep had a 4 cylinder from the factory, PO swapped a 258 with T150 and D20. the wires weren't hooked up. What's the left connector thingy on the tranny pic and the small connector in the last pic?
post #5 of 6 Old 03-30-2012, 07:04 AM
Pathkiller
1974 CJ5
The left connector on the trans is nothing, it's not used.
The small connector in the last pic on the orange wire? That's what I explained above, it's the 4wd indicator light for a Dana 300, which is not used on this application. It shouldn't be 12v positive, as the sender works on the ground circuit. So no danger of a short in leaving it dangling.
post #6 of 6 Old 03-30-2012, 07:26 AM Thread Starter
warrior1670
Great. Just for my info, what is the left connector on the trans? what is the two pin connector that I'm holding in the second pic? It's coming out of the harness with the other two connectors.
Small orange = 4wd indicator, not used
Red?/white 2 pin snap on = reverse switch
2pin plug = ??
thanks for the help
where to get OEM connectors benullman Jeep CJ Forum 4 01-12-2011 10:32 AM
where to buy good wires and connectors thord Jeep CJ Forum 9 08-26-2010 11:32 AM
MSD 6A to Duraspark connectors OldSkull Jeep CJ Forum 15 04-28-2010 11:30 AM
Need Duraspark ICM/Dizzy Connectors Monk Jeep CJ Forum 11 01-05-2010 01:58 PM
Waterproof Wire Connectors kyburz Jeep CJ Forum 6 03-13-2009 05:03 AM
