Threaded inserts in Frame gone bad... - JeepForum.com
post #1 of 4 Old 10-11-2003, 07:09 PM Thread Starter
TrappG
TrappG's Avatar
I was pressure washing the underside of my CJ today. I went to drop the t-case shield/support when I realized that 2 (of the 6) bolts holding the thing up had problems. The threaded inserts (into the frame) had come loose and the threaded part was just turning up in the frame. I was able to get one bad bolt out but the other one was just turning. I'll have to grind the head off that one. What's the best idea in getting some threads back in the frame for the bolts? Easiest solution may be to just just grind a hole in the frame in order to get a nut in there. Ultimately the hole will need to be big enough to get a wrench or socket in. Anybody had this problem or have any ideas for me? Maybe weld hole shut, drill and tap???
GT
'78 CJ7 - 304 - Hooker Headers/Sidepipes
TH400/QuadraTrac, B&M shifter (sold spring '04)
'04 Sahara - I6, 5spd bone-stock...
TrappG is offline
post #2 of 4 Old 10-11-2003, 07:47 PM
CSP
You really don't need all six bolts. Definitely don't weld the hole shut. The steel deposited by welding is next to impossible to drill through. Many people cut a slot in their frame to insert a new nut. Personally I like to drill a 1" hole with a bi-metal hole saw on the inside of the frame rail. Make it low enough that you can get an open end wrench on a new nut inside the frame. With a hole there are no points where a stress crack can develop. A good hole saw will go through the frame rail easily.
CSP is offline
post #3 of 4 Old 10-14-2003, 12:59 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Trapp,
I had this happen before. BEST thing to do is NOT to cut a hole in the sidewall of the frame to insert a nut. Buy a long drill bit, and drill thru the bottom holes, straight thru to the top of the frame rail, and then THRU-BOLT it. Your hardware store will have long high-strength bolts that will fit. AND, accessing the top of the frame rail is a piece of cake.
I don't know why this wasn't done in the first place from the factory. Damn engineers!! (I am one, too, but I tend to think with common-sense!)
4wheeler4CJ is offline
post #4 of 4 Old 10-22-2003, 02:22 PM
CJMONEYPIT
I have had to do this twice now. The first time was one of the bolts holding the steering gear bracket to the frame. I just cut a hole in the side of the frame, exposing the nut. Soak it in PB blaster and get a wrench on it. It'll either screw off or break off. I welded new nuts to the inside of the frame and welded the frame piece back on. The second one was the rear spring hanger. For that one I cut the bolt off with a reciprocating saw. Once the bolt was out, and the spring out of the way, I cut out the section with the bolt hole from the bottom of the frame, welded a new nut to the inside of that piece and welded the piece back in. With the welds ground down and a couple of coats of paint, you can't even tell there was any work done. Both repairs have held up well.
- 83 Scrambler, AMC 360, Edelbrock intake, Howell fuel injection, 32in. BFG MT, 2in. Superlift, stock axles.
- 85 CJ-10a, work in progress
CJMONEYPIT is offline
threaded frame inserts where can i get? Johnyakimo1855 Jeep CJ Forum 11 09-23-2017 07:51 PM
Anyone Know all the threaded bolt sizes on a CJ7 frame? CJman77 Jeep CJ Forum 4 02-27-2009 10:57 AM
A thread to see if it's threaded skidplate77 Jeep CJ Forum 3 04-30-2008 05:48 PM
CJ Manifold bolts? Are they threaded? joemac421 Jeep CJ Forum 6 04-14-2008 10:47 AM
Threaded Inserts For Top Davey4000 Jeep CJ Forum 1 07-31-2006 03:45 PM
