threaded frame inserts where can i get? - JeepForum.com
post #1 of 12 Old 06-21-2009, 10:26 PM Thread Starter
Johnyakimo1855
Installing a factory swaybar on a cj without one. The holes are already there from the factory. Does anybody know where I can get the threaded inserts, it looks like they were pressed in. Any suggestions?
Johnyakimo1855 is offline
post #2 of 12 Old 06-21-2009, 10:34 PM
VACJ7
VACJ7's Avatar
Do you mean Rivet Nuts or Nutserts? The use a tool to compress a portion of the insert to grab the material they are being used in.
http://www.mcmaster.com/#rivet-nuts/=2f6ymj
If the holes are there, are you sure a nut is not is not already welded inside the frame?
VACJ7 is offline
post #3 of 12 Old 06-21-2009, 10:44 PM Thread Starter
Johnyakimo1855
No there is no nut welded inside of frame sure of that
post #4 of 12 Old 06-22-2009, 05:31 AM
cwsenn
1979 CJ7
I cut some thin rectangles out of 1/4" steel. They need to be slightly longer than the frame is wide and small enough to fit in the frame opening closest to the bolt hole for the swaybar bracket. Drilled and tapped to a fine thread 7/16 or 1/2 inch (can't remember which) and fished into position with string and coathanger. Once over the hole, attached bracket with a grade 8 finethread bolt. The metal rectangle will spin in the frame and grab the sides and will be there forever. Locktite recommended.
Getting the bolt started can be a bit tricky as the rectangle will tend to slide around while you're trying to thread the bolt into it. You could shoot a little JB weld under it to hold it into place for installing the bracket.
cwsenn is offline
post #5 of 12 Old 06-22-2009, 05:38 AM
mavdog32
1980 CJ5
they are rivet nuts, i have a bunch, ill send you a handful but you will have to buy the tool! Let me know
mavdog32 is offline
post #6 of 12 Old 06-22-2009, 06:50 AM
rixcj
rixcj's Avatar
1979 CJ5
The swaybar frame brackets mount onto threaded tubes in the frame. The tubes stand proud of the frame, a little.
In this pic, the right one is there, but the left one was in rough shape...
Here's how I replaced it. I took a piece of new tube, and welded a 3/8"-16 nut to the bottom of it...
Then, welded it into the hole...
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #7 of 12 Old 06-22-2009, 07:10 PM
illinicj
1979 CJ7
I took flat bar stock, drilled holes at a spacing to match the frame, and welded nuts to it. Then I fished it into the frame and attached the sway bar brackets. The long piece of flat stock won't spin around once you get one bolt started.
illinicj is offline
post #8 of 12 Old 06-23-2009, 07:13 AM
gwolff
1978 CJ7
Look in the cj rebuilder's manual.
It is discussed in detail with pics.
gwolff is offline
post #9 of 12 Old 09-21-2017, 02:14 PM
johngeorge
i need 4 of them. i have a 78 cj7 and all of them are wasted. if you call me i will by them. 614-278-9458 thank you!
johngeorge is offline
post #10 of 12 Old 09-22-2017, 10:04 AM
KevinCJ7Jeep
1981 CJ7
The swaybar was always the first thing I removed on my CJs, even the CJ with stock suspension. Do you guys really get that much body roll without them?
KevinCJ7Jeep is online now
post #11 of 12 Old 09-22-2017, 02:36 PM
thord
Here's what i used - no welding and no fancy tools. good luck
http://www.jeepforum.com/forum/f8/re...-bolt-3262649/
thord is offline
post #12 of 12 Old 09-23-2017, 07:51 PM
chatham
you can make the tool out of a bolt and a larger nut and washer. put a 7/16 or 1/2 nut on a 3/8 bolt then a washer, thread the bolt into the rivnut and tighten it up. easy.
chatham is offline
Anyone Know all the threaded bolt sizes on a CJ7 frame? CJman77 Jeep CJ Forum 4 02-27-2009 10:57 AM
A thread to see if it's threaded skidplate77 Jeep CJ Forum 3 04-30-2008 05:48 PM
CJ Manifold bolts? Are they threaded? joemac421 Jeep CJ Forum 6 04-14-2008 10:47 AM
Threaded Inserts For Top Davey4000 Jeep CJ Forum 1 07-31-2006 03:45 PM
Threaded inserts in Frame gone bad... TrappG Jeep CJ Forum 3 10-22-2003 02:22 PM
