Thought I had a T176 - JeepForum.com
post #1 of 10 Old 10-20-2011, 10:53 AM Thread Starter
Mike78cj7
1978 CJ7
I bought what i thought was a t176. After some reading on here i checked the serial number and it ends in 89 which means its a t177. I also checked the first gear ration and its 3.82:1. Did jeep put these in cjs? All the info i've found on them says they were in fullsize jeeps only. It has the correct input shaft and factory adapter to a dana 300.
Mike78cj7 is offline
post #2 of 10 Old 10-20-2011, 11:42 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
According to Novak....
"The T177 and T178 are the J Series versions of this transmission as supplied with the 258 I6, and they feature significantly longer input shafts (than the T177) and bellhousing spacers to compensate for the deeper bulkheads of the FSJ Jeeps. The gearing differs as well. References to the T176 are largely similar to the other two versions. Failures of the T17x are more common in the Jeep trucks as they had greater weight and duty demands."
Are you sure it has the correct input shaft? Perhaps it's already been modified for your application.
Matt
Matt1981CJ7 is offline
post #3 of 10 Old 10-20-2011, 11:44 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Seem many people have found T-177 in thier CJ.
I wanted a T176 and was pleasantly surprised it was a t-177 and bolted right in place..
John Strenk is offline
post #4 of 10 Old 10-20-2011, 12:29 PM Thread Starter
Mike78cj7
1978 CJ7
Yes im sure its the right input it measures the same as the t150 it replacing I just need to get a clutch plate for a t176. The one I had was ten spline 1 1/16. I need ten spline 1 1/8.
1978 cj7 304 t176
1983 cj7 258 t4
post #5 of 10 Old 10-20-2011, 12:32 PM Thread Starter
Mike78cj7
1978 CJ7
It could have been modified I bought it and 86 axles that came from the same jeep, at least that's what I was told. Maybe amc ran out of 176's and started using left over 177's.
1978 cj7 304 t176
1983 cj7 258 t4
post #6 of 10 Old 10-20-2011, 01:01 PM
80cj
80cj's Avatar
1980 CJ5
Yes, CJ's used a short input shaft version of the T-177 I have one sitting in my storage shed that I got from a wrecked 81 CJ-5. I know of other T-177's that have come out of CJ's also. Novak and a few other web sites need to update their information. It makes sense that as AMC went to lower (numerical) rearend ratios to improve gas mileage in the 80s, that they would offset it by going to transmission with a lower first gear (T-177).
80cj is offline
post #7 of 10 Old 10-20-2011, 03:17 PM Thread Starter
Mike78cj7
1978 CJ7
Thanks 80cj. I thought maybe they used them behind four bangers to help get it going. When you think about it swaping a 3.52 1st gear for a 3.82 1st gear isn't worth the time or money for parts. Either way I'm happy with the surprise of a lower first gear.
post #8 of 10 Old 10-20-2011, 08:58 PM
80cj
80cj's Avatar
1980 CJ5
As I understand, there are a few Iron Duke 4 banger Jeeps that came with the T-176/177's. Find a bell housing from one of those and you can swap in a Chevy V-8 without and adapter.
As far as turning a T-176 into a T-177, yes it's very expensive proposition because it involves replacing several gears including the countershaft cluster gear.
80cj is offline
post #9 of 10 Old 10-20-2011, 09:01 PM
MoC
I was thinking about that a few weeks ago. Was wondering if you just had to change 1st or if there was more to it.
MoC is offline
post #10 of 10 Old 10-20-2011, 09:11 PM
80cj
80cj's Avatar
1980 CJ5
I believe you need to change the input shaft/gear, cluster gear, 2nd and 3rd gears. Everything else is the same as a T-176.
80cj is offline
possible 304 and T176 buy..... benullman Jeep CJ Forum 19 01-02-2011 12:22 PM
T176 behind a 360? thejeepman23 Jeep CJ Forum 14 04-12-2010 12:17 AM
need help with t176 jefflacy Jeep CJ Forum 6 02-06-2010 04:33 AM
3 spd or a T176 behind a 360 Johnyakimo1855 Jeep CJ Forum 1 04-17-2009 04:04 AM
What came with the T176? JOKER4INK Jeep CJ Forum 2 05-01-2006 11:36 PM
