Thinking about buying a CJ got some questions.. - JeepForum.com
post #1 of 15 Old 07-10-2004, 08:00 PM Thread Starter
durdenclub
I am thinking about buying a CJ.
-How much should I expect to pay for a "good" condition CJ?
-What all is needed if I were to put a chevy 350 in the CJ
(ie..tranny stuff...ect.)?
-what are things to look for when buying (good and bad)?
- What is the best engine to look for in a cj when buying?
I am looking at 77 and up..thanks for your help.
durdenclub is offline
post #2 of 15 Old 07-10-2004, 08:11 PM
djfuzzy
- For one in good condition, expect to pay around $4500 +/-.
- Don't know.
- Make sure there is no rust, rust is the biggest enemy of a CJ. Also, if you can, get the elusive 1986 CJ7 - it is mucho better than the rest of the years.
- The best engine of the bunch could possibly be the 258. Perhaps I am biased because my 258 works great with no snags, but I think that it is a pretty solid motor to be from 1983.
Anyway, I hope you get what you are wanting, and don't be afraid to ask questions here - these people know their stuff. Always try to talk down prices on CJs because you will need all the extra money you can get to modify it!
USMC 2006-Present
2000 TJ - some stuff
djfuzzy is offline
post #3 of 15 Old 07-10-2004, 10:55 PM
dlinzy
86 Cj7 ???
What makes the 86 so desirable?
Denny
dlinzy is offline
post #4 of 15 Old 07-11-2004, 07:34 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Widetrac axle width, possible Dana 44 rear axle, Dana 300 transfer case... plus, it's the newest of the CJs so it possibly suffers from less age-related-problems. Even so, remember that any CJ you look at will be close to 20 years old or older so expect some wear and tear (unless owner did a complete resto $$$). Heck, half the fun of owning a CJ is working on it and modifying it. Make friends with a CJ owner (we're all friendly) and maybe check out the nearest Jeep club. Might even be able to coax a club member or two into looking at a prospective purchase to help you out with an objective third eye.
BESRK is offline
post #5 of 15 Old 07-11-2004, 10:52 AM Thread Starter
durdenclub
Thanks for your help. Anyone know about putting a 350 in one of these and what it takes?
post #6 of 15 Old 07-11-2004, 11:06 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Do a Google search for the 350 swap, many people have documented it. Also, Advanced Adapters is one of the leaders in providing conversion parts for a 350 swap. Novak also has a bunch of info as well.
You will need a bunch of adapters or a new tranny, and in that case, a tranny to transfercase adapter. Aside from motor mounts, you will likely need to move your transfer case and change driveshaft length.
Most late model CJ trannies are not up to 350 power, and the AMC 20 rear end will need some beefing up also.
Good luck, and let us know what you decide.
By the way, I have an '86, but no Dana 44 rear. I think the best CJ drivetrain is the 304 V-8 and T-18 tranny. But good luck finding one of those.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #7 of 15 Old 07-11-2004, 11:18 AM Thread Starter
durdenclub
Is the 304 combo decently powerfull/fast? How common are they, can they be found easily at junk yards? Do they bolt right into any CJ or do I have to have the right engine/tranny/trans case combo? In other words with the 304 bolt onto any other tranny and trans case?
post #8 of 15 Old 07-11-2004, 01:30 PM
SamFromCO
SamFromCO's Avatar
For the 350 swap you'll need all of the stuff that CJeep mentioned. I'll mention a few more things.
You will need a new radiator and a wiring harness. Because the transfer case will probably be moved either forward or more likely backward you will need to have your driveshaft lengths altered. If you move the t-case very far towards the rear and/or want to do much of a lift then you will probably want to replace the rear driveshaft with a CV type shaft.
The 350 does make a great Jeep motor, much better than a 304 or 360 IMHO. If I had the bucks, I would definitely go for it. Here's a pic of my buddys 350 MPI in a '93 YJ:
'86 CJ7, 258 w/Mopar MPI, 4.56 gears, rear Detroit/front Truetrac, full cage, OBA, 8274, 4" lift via Alcans/Rancho, 35's on beadlocks, other stuff. Built for rocks, mud is a four letter word.
SamFromCO is offline
post #9 of 15 Old 07-11-2004, 01:53 PM
jeepsarecool
jeepsarecool's Avatar
1982 CJ7
The 258 I-6 is "decently powerful" with lots of low-end torque for its size. Sure, any V-8 will have more "power". And as for "fast" you'd have to be insane to want to go fast in a jeep. They're made for climbing over hills and through holes, not drag racing. Now, that being said, I've considered doing the 350 swap myself, and I still might someday when I have the time and money. Right now the CJ is my lone form of transportation, so I'll keep her in one piece for the time being. Good luck with whatever jeep you get.
Check out my
CJ7 - God's gift to the masochist.
jeepsarecool is offline
post #10 of 15 Old 07-11-2004, 08:15 PM Thread Starter
durdenclub
thanks for your replies, can someone tell me more about which engines go to which trannys, stuff like that. Thanks
post #11 of 15 Old 07-11-2004, 10:12 PM
GADJIT98
Durdenclub,,
Tell us why you are wanting a 350..... There may be a MUCH cheaper alternative to meeting your wishes. For example, everyone that sees my CJ7 thinks I have a v8......sounds like one, pulls like one.....Hey, the secret is never actually "showing" them under the hood The 258 is a great motor and will accomidate several trannys...the T176 is the best bang for the buck and is usually a direct bolt in once you find the correct parts and a Dana 300 t-case. I have done this swap so let me know if you need any info. Basically all you need for V8 sound and great torque is a good weber carb, good headers, and one or two flowmasters....plus it will save you a couple of grand doing the swap. Welcome to the Jeep world!
J--Just
E--Empty
E--Every
P--Pocket
Dave
83 CJ7 258, T-176, d300, Heddman Headers, Weber 32/36, 3" lift, HEI ignition, Power Brake upgrade, 33x12.5's, 3:31 gears w/ one piece axles.
GADJIT98 is offline
post #12 of 15 Old 07-12-2004, 12:29 AM Thread Starter
durdenclub
Originally Posted by GADJIT98
Durdenclub,,
J--Just
E--Empty
E--Every
P--Pocket
Dave
Well thats a good thing to know, how much are the dana 300 trans cases generally>? and How about the t176?
post #13 of 15 Old 07-12-2004, 08:56 AM
GADJIT98
You can generally find a decent Dana300 for less than $300 on EBay. T176 trannys are a bit expensive especially when the are freshly rebuilt, I paid $800 for a newly rebuilt one but I now have a source that will do it for about 6-700. You could always buy used and take your chances for less that 400.
I just did a search for them and there are a couple of dana 300 t-cases for cheap, right now there are no t-176's out there
Hope this helps
Dave
GADJIT98 is offline
post #14 of 15 Old 07-12-2004, 10:21 PM Thread Starter
durdenclub
can those trannys be rebuild by someone like my self who has a fair amount of knowledge of rebuilding transmissions?
post #15 of 15 Old 07-13-2004, 08:46 AM
GADJIT98
Shouldnt be a problem, just make sure you get a manual. I prefer to have them built by a pro since they offer a warranty.
GADJIT98 is offline
Thinking of buying 75 Cj Aalbury Jeep CJ Forum 9 08-07-2009 04:19 PM
Thinking about buying a 77 CJ5... BroncoFan Jeep CJ Forum 5 10-16-2007 10:18 PM
thinking about buying one!! biglarry Jeep CJ Forum 15 04-21-2007 02:28 AM
thinking of buying cj7 what should I look out for? r8crx Jeep CJ Forum 9 01-15-2006 07:55 PM
Thinking of buying a 55 tmohler812 Jeep CJ Forum 5 09-22-2005 08:24 PM
