Are these gear ratios compatible? - Page 2 - JeepForum.com
post #16 of 17 Old 07-29-2011, 08:26 PM
80cj
80cj's Avatar
1980 CJ5
Originally Posted by OrangeCJ-5 View Post
80cj: not sure where you saw that gearing setup but two of my Broncos came with the Dana 44 frt./ Ford 8.8 rr with 3.54/3.55 gearing respectively
The F-150's and Broncos I was referring to were the ones with a 9 inch rear and D44 front. Yes, 3.55 is a standard ratio in the 8.8. In fact I just regeared a 8.8 in 3.55 to 4.10 for a friend.
80cj is offline
post #17 of 17 Old 07-29-2011, 10:50 PM Thread Starter
twoscooterz
Originally Posted by foggybottombob View Post
One issue I know of is that the T5 tranny has 2 versions. One has a 0.86 ratio 5th and the other has a 0.76 ratio 5th.
How do I tell tell one from the other? Is there a code / stamp on my T-5 that will indicate which version I have?
'86 CJ7 Laredo, 258, Weber 38, DUI, T5 w/Hurst shifter, 4.56 Dana 30, AMC 20, Detroit TruTrac, Moser axles & Blue Torch truss, Dana 300, stock YJ springs SUA, 33" MTR's, Poison Spyder sliders, NewGen tank cover, Warn 9.5ti w/synthetic rope
twoscooterz is offline
Gear Ratios jksull Jeep CJ Forum 0 12-28-2008 09:20 AM
Gear ratios & final drive ratios Squish Jeep CJ Forum 5 10-23-2008 06:40 PM
gear ratios bohmerjr Jeep CJ Forum 3 03-01-2008 08:46 PM
gear ratios???? mike4089 Jeep CJ Forum 11 02-18-2007 11:07 AM
Gear Ratios aviator Jeep CJ Forum 3 05-02-2003 11:30 AM
