these evil little headbolts - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > these evil little headbolts
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! All Bilstein shocks & struts - Lowest Prices Ever and 1 Ton Heavy Duty Steering Upgrade Kit. New and Improved d
Unread 03-14-2014, 10:02 AM   #1
nisayingknight
1980 CJ5
How the heck do i get head-bolts out of the head of my 258, i have a leaking head gasket as well as a freeze plug at the rear of the motor. During my tare down everything was going fantastic coming out with ease and now that i just have the head bolts to pull out, there wont budge. I've heard that maybe one or maybe even three get stuck, but not all of them. so far I've tried both liquid wrench and wd-40 and both have failed to even give me any results. so does anyone have a secret way to loosen these bolts?
nisayingknight is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 10:06 AM   #2
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
2 foot long cheater bar.
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 10:06 AM   #3
thantos858
1974 CJ5
Let the penetrating oil sit for awhile then try a bigger wrench. You can try to turn them in slightly then back them out. If that fails you could try a impact gun or take it to a machine shop.
thantos858 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 10:31 AM   #4
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Figure the penetrating oil has to get past the bolt head and run down about 6" before it gets to threads.....
I second using a bigger wrench or cheater bar. I don't think I have ever heard of anyone snapping them with a bigger wrench.
If they are on that tight and need that much to break them loose, I would not be reusing those ones. They are likely to be twisted which makes a proper retorque hard to do. Once twisted, they get soft.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
bolt removal , head removal
