Are these axles worth the money? - JeepForum.com
post #1 of 10 Old 06-19-2013, 05:16 AM Thread Starter
jdhaas3
I have a 76 CJ7 with the narrow track axles, I currently have an AMC 20 and a Dana 30. Just want to get the wider axles.
http://richmond.craigslist.org/pts/3877653187.html
jdhaas3 is offline
post #2 of 10 Old 06-19-2013, 07:45 AM
holliewood61
1981 CJ7
It seems to be a decent deal concidering the upgrades. If you do much wheeling you'll still have the weak Dana 30 up front. That being said if you plan to be hard on them hold out for a set of Dana 44's out of a scout or waggy. They are wider than the wide trac but much stronger. If you mostly run up and down the road id say jump on them as long as the gearing won't be too low.
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline
post #3 of 10 Old 06-19-2013, 08:09 AM Thread Starter
jdhaas3
I just heard back from him and they are both lock rite lockers in the front and rear. At this point its little to no wheeling nad just pounding pavement/sand right now. I am really just trying to get away from the narrow tracks for fairly cheap.
jdhaas3 is offline
post #4 of 10 Old 06-19-2013, 08:16 AM
holliewood61
1981 CJ7
You can pick up I unmodified set of wide trac fairly cheap. Look on the c'ville Craigslist I think there's a guy around Zion Crossroads with some
08 WK bone stock
00 WJ daily driver
60 CJ5 tore down
post #5 of 10 Old 06-19-2013, 08:19 AM
wm69
With the upgrades I'd say they're worth it. Regearing an axle will cost you most of what he wants for those. That said, what size tires are you running and do you need 4.11? If you just have a toy or have big tires I'd say jump on it. If you have a daily driver with 31's your engine will be screaming on the highway with those gears.
Still, very reasonable price given the upgrades.
wm69 is offline
post #6 of 10 Old 06-19-2013, 10:05 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Heck if that was closer I would buy them myself.
John Strenk is online now
post #7 of 10 Old 06-19-2013, 11:07 AM
wm69
Kinda what I though too John.
wm69 is offline
post #8 of 10 Old 06-19-2013, 11:29 AM
Jawbox
What about just changing the backspacing with a different wheel or adding some small spacers? If you're not really wheeling, this might be a more reasonable option.
I mainly suggest it because it doesn't seem like it would be much of an upgrade except in width.
Jawbox is offline
post #9 of 10 Old 06-19-2013, 11:54 AM
wm69
Lockers, one piece alxes, heim joints, 4.11's.......I'd say that's a HELL of an upgrade
Front Dana 30, Rear AMC 20 wide track out of 1982 CJ. Both equipped with lockers, 4:11 gears, 5 lug, stainless diff covers, new hubs, hiem joints on drag link, yukon flanged rear axle shafts. Ready to install!
wm69 is offline
post #10 of 10 Old 06-19-2013, 01:47 PM
BadHabit80cj7
1980 CJ7
It's even worth the freight charge to have those with all the addons.
BadHabit80cj7 is offline
