Thermostat housing? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Thermostat housing?
07-15 JEEP JK Inner axle tube SleevesBead Lock Wheels! Raceline, Trail Ready, & Trail-GearExtremeTerrain's July Sale - Save up to 35%!
Unread 07-01-2012, 08:50 AM   #1
Mlaughlin8
1980 CJ5
Thermostat housing?
I Read somewhere on here that a 4.0 ltr thermostat housing will bolt up to a 258 block with no extra mods! Is this true??? Reason is I think the 4 ltr one has a port for a temp gauge, and that's what I need since I can't find a place to put my aftermarket mech temp gauge fitting.. I have a header so there is no place to put my fitting!
Mlaughlin8 is offline   Reply With Quote Quick reply to this message
Unread 07-01-2012, 12:14 PM   #2
1986cj
They do. I just did this yesterday.
1986cj is offline   Reply With Quote Quick reply to this message
Unread 07-01-2012, 12:17 PM   #3
davbytrace
1979 CJ7
Any idea if it would fit a V-8.
davbytrace is offline   Reply With Quote Quick reply to this message
Unread 07-01-2012, 03:45 PM   #4
Mlaughlin8
1980 CJ5
Awesome! Did you do it for the same reason??? How did it turn out? And, would the thermostats be the same since the housing is interchangeable???
Unread 07-01-2012, 04:09 PM   #5
VACJ7
Hockey Rules!
VACJ7's Avatar
Yes, thermostat - gasket - housing are all the same between the 258 and 4.0. This is the housing with the threaded bung I use for a temp probe to control my Contour fans.
'84 CJ-7 | REBUILD IN PROGRESS
VACJ7 is offline   Reply With Quote Quick reply to this message
Unread 07-01-2012, 10:50 PM   #6
1986cj
I am changing out mine for the cooling temp sensor for MPI. T stat should work but I changed mine to a 195 for the mpi.
Unread 07-02-2012, 01:31 AM   #7
jayzcj5
1978 CJ5
To thanks guys, you read my mind in this cause I have been wondering the same thing. I too want the t-stat with the opening for a temp gauge. Hesco has one with two openings....you could run ur fans and a temp gauge.....awww sh!#
jayzcj5 is offline   Reply With Quote Quick reply to this message
Unread 06-20-2015, 08:42 PM   #8
andysbarker
1980 CJ5
I pulled a 4.0 housing off of a jeep Cherokee today at the salvage yard to have the tapped hole for a temp sensor. I installed in on my 1980 258, but I have some concerns about it. The outlet neck angles back toward the engine and is so close to the valve cover, I barely have the hose clamp on the neck. The 258 housing does not angle back. The flow is also very restricted compared to the 258 housing. I'm wondering if I got the wrong housing.
andysbarker is offline   Reply With Quote Quick reply to this message
Unread 06-20-2015, 08:58 PM   #9
RadioRadio
1980 CJ5
Pics? Is your housing leaking? I've got a 4.0 water neck and its tight along the valve cover, but still works fine. Unless it leaks or your temp goes wild, I wouldn't worry about it.
RadioRadio | 1980 CJ-5
RadioRadio is offline   Reply With Quote Quick reply to this message
Unread 06-21-2015, 09:21 AM   #10
bob4703
1974 CJ5
Had the same problem. Works! As stated clearance a little tight, but can be done.
For a V8 look for a late 60' early 70's J20. Summit Racing will have a picture you can look at.
bob4703 is offline   Reply With Quote Quick reply to this message
Unread 06-22-2015, 05:05 PM   #11
andysbarker
1980 CJ5
I tired to use the spring clamps that were on the Cherokee, but there is not enough room. The clamp for the radiator hose hits the valve cover. I need to switch back to the band screw/clamp.
