Thermastat house - JeepForum.com
post #1 of 20 Old 01-16-2012, 10:27 AM Thread Starter
jamie0921
1973 CJ5
Thermastat house
Where is it
jamie0921 is offline
post #2 of 20 Old 01-16-2012, 10:40 AM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
Front of engine...passenger side away from dizzy, almost dead center from carb. Follow the black hose from Radiator.
EDIT: This is a Jeep/AMC engine, no? It is part of the intake manifold.
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #3 of 20 Old 01-16-2012, 10:42 AM
CSP
The upper radiator hose is attached to the thermostat housing.
CSP is offline
post #4 of 20 Old 01-16-2012, 11:14 AM Thread Starter
jamie0921
1973 CJ5
Ok this is it , than on the back there is a plug is this where I connect
My heater core
post #5 of 20 Old 01-16-2012, 11:47 AM
benullman
1981 CJ7
My heater core
Someone eliminated your heater core. The second hose goes between your water pump and thermostat housing. Its being 'jumped'. You need a line from the water pump to heater for then back to the housing. That bolt on the back it there for a temp. Sender.
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #6 of 20 Old 01-16-2012, 11:50 AM Thread Starter
jamie0921
1973 CJ5
so i need to eliminate this smaller braided hose and connect heater core to these to spots
post #7 of 20 Old 01-16-2012, 11:56 AM
walkerhoundvm
1981 CJ8
You have a new heater core put in, right? POs usually do things for a reason, in this case I'm guessing it was because the heater core was leaking all over the cabin.
walkerhoundvm is offline
post #8 of 20 Old 01-16-2012, 12:06 PM Thread Starter
jamie0921
1973 CJ5
yes it didnt have a heater to begin with
post #9 of 20 Old 01-16-2012, 12:10 PM Thread Starter
jamie0921
1973 CJ5
Ben
ok thanks so if my heater core goes in the two holes that will be created by eliminating this hose than whats the other hose in this pic on the left side of the pump thats 2 inches long thats plugged off (you can seeit right thru the belt there)
post #10 of 20 Old 01-16-2012, 12:23 PM
VACJ7
VACJ7's Avatar
An overhead pic of the engine pay will probably make it easier to show you what goes where.
'84 CJ-7 |
VACJ7 is offline
post #11 of 20 Old 01-16-2012, 12:30 PM
82JeepCJ7
1982 CJ7
The heater connects on one end where the pipe plug is in the rear of the first picture of the intake manifold. There should be a 90 fitting that goes into that hole. The hose from the heater core connects to the passenger side of the water pump. The braided hose you have from the water pump up to the intake is the bypass hose. Leave it alone. The plug on the thermostat housing is a good place to put a manual temperature gauge sending unit.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #12 of 20 Old 01-16-2012, 12:34 PM Thread Starter
jamie0921
1973 CJ5
so remove the blue plug on the back of the manifold and second hose goes to the black hose that is stubbed on the left side of the pump(and leave the bypass alone) is this correct
post #13 of 20 Old 01-16-2012, 01:03 PM
82JeepCJ7
1982 CJ7
Take the silver square headed plug out. That is where the line to the heater core goes. The line from the heater core goes to the port on the water pump you can see between the belt on the alternator.
post #14 of 20 Old 01-16-2012, 01:20 PM Thread Starter
jamie0921
1973 CJ5
i dont see a silver square plug only the blue? someone said that it was for a manual temp guage sending unit
post #15 of 20 Old 01-16-2012, 01:22 PM Thread Starter
jamie0921
1973 CJ5
This help
