Is there a Dana 44....... - JeepForum.com
post #1 of 20 Old 01-20-2010, 12:52 PM Thread Starter
78treehugger
1980 CJ7
Is there a Dana 44 that is the same width of the model 20? I have NT axles but I can add wheel spacers to get to 54.5". I would like to upgrade my front axle and was curious if there is a Dana 44 the same width. I have looked and can't find any. All I have found is Chevy's have the same drop I need but I can't find a link to the lengths.
Does anyone have a link to the lengths and drop sides to axles? I will eventually upgrade both axles but not for a few years. Thanks.
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage
It's easier to get forgiveness than permision.
Salad is what food eats!!!
78treehugger is offline
post #2 of 20 Old 01-20-2010, 01:02 PM
CSP
If there was you wouldn't see so much info on cutting down other Dana 44s.
Unless you can find someone selling a 44 modified for a CJ, you're out of luck.
CSP is offline
post #3 of 20 Old 01-20-2010, 01:26 PM Thread Starter
78treehugger
1980 CJ7
That's what I figured. Thanks CSP.
post #4 of 20 Old 01-20-2010, 01:41 PM
Darthteddy
1955 M-38
Is the 44 full floater rear out off the m38a1 the same width?
Dylan-19 and Yearning
93 Rubigrand - Sold... :'(
95 Grand Cherokee Limited - 5.2 Mall Crawler
55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders....
Darthteddy is offline
post #5 of 20 Old 01-20-2010, 01:47 PM
JoonHoss
2011 JK Wrangler
some 1986 CJ7's came from the factory with D44 rear axles stock.
http://www.jeepgod.net/d44.html
rare? yes, but they do exist.
witness:
http://cleveland.craigslist.org/pts/1538710607.html
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #6 of 20 Old 01-20-2010, 01:52 PM
junkur
i think he is looking for a front D44. as far as the AMC 20, if you have narrow track, i would think a D44 out of a 72-75 CJ would be the same width. and yes, some '86s came with a D44 rear. they are really not that rare. i've seen plenty 86's with it and have an '86 of my own with the D44...maybe its a northeastern thing lol
junkur is offline
post #7 of 20 Old 01-20-2010, 01:59 PM
JoonHoss
2011 JK Wrangler
Originally Posted by junkur View Post
i think he is looking for a front D44. as far as the AMC 20, if you have narrow track, i would think a D44 out of a 72-75 CJ would be the same width...
I went off his first line, "is there a D44 the same width as the model 20..."
in any event, more D44 info
http://www.jeeptech.com/axle/d44.html
http://www.jeeptech.com/axle/d44f.html
Hoss
JoonHoss is offline
post #8 of 20 Old 01-20-2010, 02:29 PM
alex211
1995 XJ Cherokee
I have the off-set 44 in the rear of my jeep. I just need to find a nice 30 for the front, or put some disks on my 27 which is probably what I will do.
95 xj bone stock for now
alex211 is offline
post #9 of 20 Old 01-20-2010, 02:31 PM
80cj
80cj's Avatar
1980 CJ5
M38A1 rear is a semifloating tapered axle 44. In regards to width, I think they're a little narrower.
80cj is offline
post #10 of 20 Old 01-20-2010, 02:34 PM
CSP
Yes they did. There are also D44s found in '72-75 CJs that are the same width as his AMC 20. Then there are those found in Commando's which are the same width and even have the same spring perch spacing.
The thing is:
CSP is offline
post #11 of 20 Old 01-20-2010, 02:48 PM
foggybottombob
You probably already know it but the scout D44 from 72-80 is about 2" wider than the stock CJ7 front axle. The scout axle has zero degrees caster with the pinion horizontal. (58" WMS to WMS).
foggybottombob is offline
post #12 of 20 Old 01-20-2010, 03:14 PM
alex211
1995 XJ Cherokee
Why does the scout axle have 0 caster, how did it work in a scout?
alex211 is offline
post #13 of 20 Old 01-20-2010, 03:16 PM
CSP
The OP's narrowtrack CJ7 front axle is only 54.5".
CSP is offline
post #14 of 20 Old 01-20-2010, 06:15 PM
John N
1981 CJ8
Their frames were shaped differently.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #15 of 20 Old 01-20-2010, 06:18 PM
alex211
1995 XJ Cherokee
But then wouldn't they have a bad u-joint angle?
alex211 is offline
1985 CJ8 swapping in Dodge 1 ton Dana 44 front and Dana 60 rear?????????? JeepScrambler Jeep CJ Forum 8 05-21-2012 06:30 PM
Switch from T176 and Dana 300 to T150 and Dana 20?? Need Advice CJ5Freak Jeep CJ Forum 11 07-26-2008 06:56 AM
Swapping Disc Brakes from 81 Dana 30 to 76 Dana 30 PortlandCJ76 Jeep CJ Forum 2 05-13-2007 04:11 PM
dana 44 spindles bolt to dana 30 nuckles? CJ7Laredo Jeep CJ Forum 2 09-26-2006 10:55 PM
Scout dana 20 vs jeep dana 20 (internal gears) pityocamptes Jeep CJ Forum 3 05-18-2004 11:19 PM
