Is there anything extra that i need when i install a 2.5" lift - JeepForum.com
post #1 of 4 Old 03-27-2004, 10:46 PM Thread Starter
jeff83cj7
If i were to install a 2.5" lift for my '83cj7, what extra things would i need to accompany it?
jeff83cj7 is offline
post #2 of 4 Old 03-28-2004, 09:48 AM
jadams68
jadams68's Avatar
Only on rare occasions have I seen guys with a 2.5" lift drop the transfer case or shim the axles. You should be fine without either of those.
If when you're done with the springs and shocks, just check your brake hoses to make sure they are not banjo string tight. You may have to get newer, longer ones.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 4 Old 03-29-2004, 09:27 AM
MR.CJ-7
All I added was extended brake lines because the one in the rear got pretty tight when flexed
Former CJ'er
MR.CJ-7 is offline
post #4 of 4 Old 03-29-2004, 10:12 AM
OL YELLAH
OL YELLAH's Avatar
I got good use out of my digging bar, torch, and grinder when my rusted parts needed a little persuasion. You might want to keep that in mind.
1979 Jeep CJ-5; 1972 258 (Pacesetter Header, Weber Carb, Wrangler Aluminum Intake, 2.5" Exhaust Straight Through w/ Thrush Mufflers); 2.5" BDS Lift; 1" Daystar Body Lift, Herculiner; RJS Belts; 33" Interco Trxus M/T Tires; Xtreme Alloy Wheels; 2.5" Perfomance Wheel Spacers; TFI Upgrade.
OL YELLAH is offline
Howell TBI Install: Tach and "Check Engine Light" question jatepper Jeep CJ Forum 10 07-19-2009 09:07 AM
4" lift install (lots of problems) 76silvercj5 Jeep CJ Forum 2 08-29-2008 07:06 PM
What is this "centering block" that I have to remove to install 1-piece axles? part.changer Jeep CJ Forum 11 06-18-2007 04:12 PM
3" Black Diamond Lift ... what else is needed for the install? cj newbie Jeep CJ Forum 13 04-09-2007 08:18 AM
Extra body weight on CJ-7 lift only in a jeep cj Jeep CJ Forum 2 05-23-2006 01:08 PM
