Thanks Jeephammer! Teamrush once again.
| Truck-Lite's New LED Headlamp Series | CURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee! | Poison Spyder DeFenders™ - "Tubeless" Jeep Fende |
#1 | |
The title says it all. I have an open "thank you" to Jeephammer. Just fired my Jeep up for the first time after this relatively cheap upgrade. Wow, what a difference. Maybe I had other underlying problems with my '80 model CJ5
258, because the difference is noticeable big time. What I did: Went to Pull A Part and got an E-coil, wiring connector, and mount off an 80s model Ford something for $5.00. I did have to educate the seller its an ignition coil. I then picked up a premium cap, button, and wires for an 82 Ford F150 at Autozone. My junkyard E-coil had the condenser which I installed on the Jeep too. I noticed some do not have it. After modifying the E-coil mount, I installed it right where the factory coil was. Quick note about the E-coils: I looked a 3 of these coils before finding one without a damaged high voltage wire connector. Check it out good on used stuff. Thanks again JH. ![]()
#2 |
I did the same upgrade TeamRush and used Ford E Coils, PLUS: added grounds to head and Ground Input to the DuraSpark Ignition Modual (black wire). I got similar results WOW!!!
Estimate it added 15% to the mileage and pep of a newly rebuilt 258 with all new parts. I also posted a thank you to JeepHammer for the same reason, Thanks again, Fred Everone should do this upgrade. |
#3 |
To John and JH. |
#4 |
Hey Fred, what kinda mileage are you getting since the upgrade vs before?
#5 | |
Installed a Summit MultiSpark Discharge Ignition that bumped the MPG up to 25/26 mpg. I used the digital version with the rev limiter. I have since opened up the run jet on the weber 34 a bit and expect to be in the 23/24 mpg range. Pulls pretty strong from 1000 to 4000 rpms. Just put the CJ away till next spring. Fred |
#6 |
Wow, thats impressive. Ill be tickled if Im anywhere near 20 on my setup.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
