Th400 output shaft removal - JeepForum.com
post #1 of 20 Old 06-13-2010, 03:51 PM Thread Starter
Wrangler11
Wrangler11's Avatar
I have the qudtratrac off and need to remove the output shaft in order to install the advance adapter's adapter for a np231 transfer case. My question is, how does the output shaft come out?
2002 Grand Cherokee Limited
1994 Toyota Land Cruiser (camping offload toy)
Wrangler11 is offline
post #2 of 20 Old 06-13-2010, 04:14 PM
motiv8ya
1979 CJ7
You have to tear down the entire transmission, It's the "first thing" you put back into the case upon reassembly.
motiv8ya is offline
post #3 of 20 Old 06-13-2010, 04:36 PM Thread Starter
Wrangler11
Wrangler11's Avatar
That is what I was afraid of. Does anyone know if the output shaft has to come out in order to install advance adapter's adapter? The instructions are junk.
post #4 of 20 Old 06-13-2010, 05:15 PM
motiv8ya
1979 CJ7
Yes, you must install the Output shaft that comes with the kit for it to work. The TH400/Quadratrac 10 spline output shaft won't work for the swap.
motiv8ya is offline
post #5 of 20 Old 06-13-2010, 05:54 PM Thread Starter
Wrangler11
Wrangler11's Avatar
Ah crap. I guess I will be dropping he trans this week then.
post #6 of 20 Old 06-13-2010, 08:29 PM Thread Starter
Wrangler11
Wrangler11's Avatar
Will I have to take anything apart to get to the input shaft once the transmission is down and opened?
post #7 of 20 Old 06-13-2010, 10:19 PM
CjAl
1980 CJ7
you have to take EVERYTHING out. have you ever looked inside an auto trans?
you nee internal and external snap ring pliers and there is a special clutch pack compressor you wil need. Do yourself a favor and find someone to do it for you and rebuild the trans while you are at it
CjAl is offline
post #8 of 20 Old 06-13-2010, 10:21 PM
CjAl
1980 CJ7
here i what you got
CjAl is offline
post #9 of 20 Old 06-14-2010, 08:45 AM Thread Starter
Wrangler11
Wrangler11's Avatar
Holly cow! I haven't done it before, but my brother has several times.
post #10 of 20 Old 06-14-2010, 08:55 AM
CjAl
1980 CJ7
it comes out in individual clutch pack assemblies. If you look you will see all the clutches go into one drum assembly. Take them out, keep them CLEAN and set them in the proper order for reassembly. the hard part is the last clutch pack that needs to be compressed in order to get the retainer out. that is if the TH400 is the same as the 350's i've done. We made a home made compressor for it.
I would never go through the PITA to disassemble an auto trans without rebuilding it. You can buy a rebuild kit from NAPA or anywhere and replace the parts as you reassemble. just remember to soack the clutches in ATF before assembling them
CjAl is offline
post #11 of 20 Old 06-14-2010, 10:01 AM Thread Starter
Wrangler11
Wrangler11's Avatar
Thanks for the tips. Can you rent a compressor for the last clutch? It looks like it is between $200-$300 for a rebuild kit. No too bad.
post #12 of 20 Old 06-14-2010, 11:03 AM
CjAl
1980 CJ7
I don't think it's something anyone would have to rent but you could probably take it to a small trany shop (not a big chain one) and ask them to do it for you. would probably do it for free or just a few bucks. Personally I'd have them compress it, relace the rear shaft, put the new clutches in the pack and put it back in. Otherwise you wil have to run it BACK to the shop to have them compress it to put it back together.
I actually think we stood the case on end and put a big piece of pipe down inside it and had somome ush it down by paying on it while another person put the retaining ring back in. the compressor we built didn't work real good and broke as soon as we got it apart
CjAl is offline
post #13 of 20 Old 06-14-2010, 12:38 PM Thread Starter
Wrangler11
Wrangler11's Avatar
Sorry if I sound like a moron, but I have never worked on a transmission before. Do I have to take the whole trans to a ship to have the rear clutch pack taken out? There are a few shops in the area that I could probably go too. I've just spent so much money on everything the last month and really do not want to have to spend anymore especially to have someone else do the work.
post #14 of 20 Old 06-14-2010, 12:57 PM
CjAl
1980 CJ7
you can get the forward clutch pack out by yourself with just some snap ring pliers. whe you get down to the one you need a compressor for it will be the last pack in the case so you will have done most the work by then.
again this is going off my memory of doing a th350 which was about 20 years ago
CjAl is offline
post #15 of 20 Old 06-14-2010, 02:23 PM Thread Starter
Wrangler11
Wrangler11's Avatar
Hopefully they are similar. Any idea on how heavy the trans is and how heavy it will be with everything out besides the last pack? I need to make sure I will be able to bring it somewhere if needed.
Dana 20 T/C Rear Output Shaft Bearing Removal Question Mud Machine Jeep CJ Forum 0 04-09-2007 07:25 PM
How do I pull the output shaft from a T18? Bendystraw11 Jeep CJ Forum 5 02-09-2007 07:22 AM
T-18 6 spline output shaft to Dana 300? Bard Jeep CJ Forum 4 04-09-2006 07:10 PM
tranny output shaft seel CGrugger Jeep CJ Forum 2 03-21-2006 06:27 AM
Trans Output shaft play pf1130 Jeep CJ Forum 4 05-21-2005 08:16 PM
