TH400 just stopped - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > TH400 just stopped
The ULTIMATE "Selectable" Locker System! BroughRough Country Lift Kits and Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-15-2014, 12:37 PM   #1
Zackmul
1977 CJ7
TH400 just stopped
So, last time i went mudding, i drove through two puddles made it through the 1st one fine but when i got out of the second one my jeep died, i got water under the distrupiter cap. after cleaning out the water it fired up but the transmission wont go into any gear.. im confused on why any ideas? replace that vacuum modulator?
cj7 304 v8 automatic 1977
Zackmul is offline   Reply With Quote
Unread 07-15-2014, 12:41 PM   #2
BigPheJeep
1979 CJ7
Does it physically go into gear but not move? I'm guessing it is a Quadratrac. If so, is in Emergency or Normal mode?
BigPheJeep is offline   Reply With Quote
Unread 07-15-2014, 03:43 PM   #3
lucdog
lucdog's Avatar
1980 CJ5
Have you checked the linkage from the column to the tranny, and the arm that bolts to the side of the transmission? Did you knock the low range unit, if you have one, into neutral ?
1957 WILLYS pickup, needs work.
1973 J 4000,
1978 CJ7 DD.
1979 CJ7 360, TH400/Quadratrac trail Jeep.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7 pretty weekend and sometimes to work Driver in the summer, My first rebuild, if the Q-trac and 5 are broke, this one is the one to take. its just as capable as the other 2, except nice paint.
1984 Grand Wagoneer, 1 ton axles, great 360/727, and a big a$& tree fell on it .
1989 YJ the CJ to YJ conversion.
2005 TJ Rubicon.
2011 Grand Cherokee Laredo 4x4, Mrs. LUCDOG's DD.
Lots of parts not for sale, i'm a hoarder.
lucdog is offline   Reply With Quote
Unread 07-16-2014, 02:47 PM   #4
carnuck
1984 J-Series Truck
Does it grind when you put it into park from drive? If so, tcase in neutral or toasted.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
http://tinyurl.com/jimsclads
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline   Reply With Quote
Unread 07-18-2014, 01:08 PM   #5
Zackmul
1977 CJ7
the quad tec is in normal mode. it doesnt feel like it goes into any gear, and all the linkage is operating properly.
Unread 07-20-2014, 10:26 PM   #6
carnuck
1984 J-Series Truck
Does the trans lock in park? If not, then the linkage may be broken inside.
FOR SALE STUFF
Unread 07-30-2014, 05:47 AM   #7
2Xtreme
1979 CJ7
Did you physically inspect both ends of the linkage, or just verify that the shift lever works as expected?
2Xtreme is offline   Reply With Quote
