TFI Upgrade - JeepForum.com
post #1 of 5 Old 06-18-2004, 07:40 AM Thread Starter
LilRedCJ
TFI Upgrade
Anyone have any feedback on the TFI upgrade?
My 4.2 starts great but idles rough, loses power around 3 to 4k RPMs and the exhaust flat out stinks. Is this kit really worth the money and trouble?
My stock Distributor Cap sits pretty close to the block and oil stick. Is there a space issue?
Also, does the new coil mount where the stock one sits?
Thanks...
'90 Full Bronco
'95 Full Bronco
'85 Jeep CJ 7
Past: '84 Cherokee Chief / '83 CJ 8
LilRedCJ is offline
post #2 of 5 Old 06-18-2004, 09:11 AM
jadams68
jadams68's Avatar
Probably one of the best mods I did to my 84 CJ.
Parts are relatively cheap and easy to find at any auto parts store.
The new coil can dangle off of the stock coil clip if you want. Others wire tie it to the battery tray or fabricate a mount on the fender.
Here's my writeup if you're interested.
http://www.bustedjeep.com/projects/tfi.asp
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 5 Old 06-18-2004, 09:33 AM
CSP
The symptom of stinky exhaust tells me you have more than ignition problems, so don't expect TFI to solve everything. It will help, but me thinks you need some carburetor work as well.
CSP is offline
post #4 of 5 Old 06-18-2004, 09:37 AM
lord_byron
lord_byron's Avatar
Does anyone really run a 4.2 at 4k rpms? I don't even run my 4 cyl TJ like that...
lord_byron is offline
post #5 of 5 Old 06-18-2004, 03:02 PM
gosupes
I don't always run it past 4K but it is nice to be able to. The TFI is well worth the cost.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
GM HEI Upgrade for AMC V8 jayhawkclint Jeep CJ Forum 4 06-28-2007 02:30 PM
Upgrade to 360? Scrambler1 Jeep CJ Forum 5 09-19-2005 06:36 PM
258 EFI upgrade & YJ spring upgrade jeepin'bo Jeep CJ Forum 2 04-08-2005 06:02 AM
anybody use this kit for Ign upgrade? Geer_hed Jeep CJ Forum 10 11-26-2003 11:34 AM
just did TFI upgrade... NJCJ7 Jeep CJ Forum 8 10-31-2003 04:58 PM
