Quantcast tfi question - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > tfi question
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 07-21-2008, 07:08 PM   #1
tolobill
tfi question
hi, i am doing the tfi upgrade on a 80 cj7 with ford 302. just a couple of questions for a dummy like me, no concept of electrical connections. i have read all the internet info and still dont understand. i have the msd cap rotor set 8414 and wires 700313. on my current coil set up i have 1 white wire going to positve side of round coil, and 1 white wire and 1 green wire going to negative side of coil, i also have tach. on the connector i got from pepboys for the tfi ecoil, it has 2 green and white wires and 1 red wire how do i connect these to my current wires. i know this issue has been beat to death thanks for the help
tolobill is offline   Reply With Quote
Old 07-22-2008, 02:42 AM   #2
JeepHammer
Running On Empty...
1973 CJ5
MSD p/n 8414 is the cap adapter, cap and rotor for a Ford V-8 engine from about '58 to '85 and will work on most current Motorcraft distributors.
As for your plug wires, I can't find reference to a '700313' set of plug wires.
OK, The Positive (Red) side of the new coil connector will connect to the 'White Wire' that is now connected to the positive side of your coil.
The Negative (Green) side of the new coil connector will connect to the 'White Wire' & 'Green Wire' on the Negative side of the current coil.
If your Tach is currently working, it will work with the new coil and connector.
Red is Positive, Green is Negative.... ALWAYS.
And yes, this has been beat to death, but not by someone that has all 'White' wire color coding...
BTW, that's pretty odd...
I'm sure if you strip the harness back a ways, you will find some color in the wire insulation that will more or less match your new connector.
JeepHammer is online now   Reply With Quote
Old 07-23-2008, 02:24 PM   #3
tolobill
ok i think i got it. but what do i do with the 2nd green wire on the new connector, do i need a resistor or capacitor. also should i mount the new ecoil next to the module on the fenderwell, that would requie a rather loon spark plug wire. thanks again for all your help.
Old 07-23-2008, 03:48 PM   #4
JeepHammer
Running On Empty...
1973 CJ5
Use it for something or clip it off if it's not hooked to anything.
Resistor should be built into your existing Jeep Harness.
Capacitor might be needed if you can hear the ignition in the radio.
It's traditional to mount the coil next to the distributor.
On the 302 Ford you will find coil mounting bracket bosses cast/machined/threaded in the intake for the ignition coil/bracket.
Use those.
Remember, an E-core coil can be mounted in any direction,
While a Canister coil is oil filled and MUST be mounted right side up to work correctly.
Actually, that would require a rather long COIL WIRE...
And it's not that long if you mount it on the drivers side inner fender...
That's where I mounted my coils.
Old 06-29-2011, 08:45 PM   #5
243
NOT a Web Wheeler
243's Avatar
1983 CJ7
Btt
1983 CJ-7, 258, T177, D300, 3.54’s and 32” KM2’s
Many thanks to those with contributions to my build:
twoleos617, Jim1611, Yellow85CJ, kickingprop, CJnPA, Fatman, Grewel, -boom and VACJ7...oh crap, and EXPOSED too!!!
Money Pit >>>http://www.jeepforum.com/forum/f8/daves-83-cj7-build-891652/
...a jeep ensures you don't have a drinking, drug or woman problem: always dirty, broke and tired. "ACAD_Cowboy"
243 is offline   Reply With Quote
Old 06-29-2011, 09:08 PM   #6
JeepHammer
Running On Empty...
1973 CJ5
Again, the point of a three year old thread?
Old 06-29-2011, 09:51 PM   #7
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Originally Posted by 243 View Post
Btt
Please stop.. I start my days at 5am.. it's now 10:49pm and I'm trying to run thru the CJ and Fabrication Forums to see if I need to fix anything.. this kind of posting hurts. I've already deleted 3-4 threads like this..
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
