TF999 kickdown...how to know if it needs to be adjusted - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > TF999 kickdown...how to know if it needs to be adjusted
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comXHD Heavy-Duty Hood Latches for JK and TJ available at OcoThe ULTIMATE "Selectable" Locker System! Brough
Unread 04-11-2014, 11:28 AM   #1
Gigemags05
1980 CJ7
I have a Lokar kickdown cable installed on my tf999 and 4.0.
I am not sure if its adjusted correctly. How do I know if it needs to be adjusted? Are there symptoms while driving?
Gigemags05 is offline   Reply With Quote
Unread 04-11-2014, 05:27 PM   #2
timo22
On Chrysler transmissions, the kick down controls not only downshifting but also up shifting. At our shop we always set them to shift into 2nd at about 15 mph and 3rd about 30mph. Just remember the sooner you get into the kick down, the later it will shift. Hope this helps...timo
timo22 is offline   Reply With Quote
Unread 04-11-2014, 06:41 PM   #3
Gigemags05
1980 CJ7
Ok, so I need to see how fast I'm going when it shifts into 2nd?
Unread 04-12-2014, 08:06 AM   #4
Gigemags05
1980 CJ7
What are the symptoms if it's too tight? Too loose?
Unread 04-12-2014, 08:33 PM   #5
timo22
If it's too tight,it will shift later. If it's too loose,it will shift sooner. Like I said,under normal acceleration, it should shift about 15 and 30. That's a good baseline. With it set there, you will notice that the faster you accelerate. The later it will shift. Tim
