Tf999 - JeepForum.com
post #1 of 8 Old 08-03-2006, 09:25 AM Thread Starter
ckritcoad
Tf999
What are your opinions on the TF999 3 speed auto? How well would it work with a 350 and 35's?
Thanks,
ckritcoad is offline
post #2 of 8 Old 08-03-2006, 09:43 AM
BLS33
Chief of the brain police
BLS33's Avatar
You shoulod probably upgrade, or at least get some kickdown linkage
BLS33 is offline
post #3 of 8 Old 08-03-2006, 09:50 AM
Salt Hay
1978 CJ5
I had one for years in an '84 CJ-7 behind a 360. It's a good trans , has a nice low 1st for an auto , but a 350 and 35's are probably too much for it ..........
Salt Hay is offline
post #4 of 8 Old 08-03-2006, 10:03 AM
jeepskate
It'll live if you're not a leadfoot. It's essentially the same basic trans as the 904 only a bit beefier and has served many people well behind V8's in it's Mopar cased version. Make sure the throttle valve (kickdown) linkage is installed and properly adjusted, run a bigger pan for more fluid, and run a cooler.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #5 of 8 Old 08-03-2006, 10:26 AM
bdmonist
WTF is that?
bdmonist's Avatar
I have a 360, 999, and 35's and so far have not had any problems. I am currently researching installing a SBC 350. I spoke with Novak Adapters and they recommended against the 999 with a 350. Their recommendation was a 700R4 or TH350. I did some research on my own and I also now believe those are superior transmissions by far. The 700R4 has an overdrive which will help on fuel as well. If you already have the setup you are asking about, I would let it go until it breaks - that's what i am doing. If you are looking for a setup to install, I would not install the 999 with a 350.
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #6 of 8 Old 08-03-2006, 11:25 AM
86cj74.2L
86cj74.2L's Avatar
The 999 in my inlaws 86CJ7 258 has 130k on it. When the original motor died at 115k I had the local tranny shop go through it because of the mileage it had. (even though it still had a tight kick shifting into second)
They put new bushings and seals in and slapped it back together. It looked brand new inside.
Its a good tranny! The drag racers prefer it over the 727 because of its lower 2.75:1 first gear ratio and sucks up less horsepower to spin.
Chrysler trannies like to be kept cool. Go to a swap meet and find a tranny cooler out of a Cummings plum it into the cooler lines before the rad, put a remote filter on it from Perma Cool (or Summits own version which is the perma-cool without the temp gague) and put it in the return line going back to the trans and you will have no problems.
If you're running 35 and do not change your axial ratio you will kill a turbo 350 and a 700r4 from the heat the torque converter is making from it slipping with the taller overall gear ratio the 35's change it to.
I've seen a stock V6 kill a 700r4 with mild towing which would be equivalent to the extra work it would take to spin 35s. I've seen plenty of turbo 350 die as well on full bodied Chevy's with a mild 350 under the hood.
Get a Dakota automatic trans/transfer case and bolt the tail section and transfer case to your 999 and have your overdrive unit. Changing your drive shaft lengths (according to a friend of mine who uses one in his 10.20 second Demon) will need to be done.
86cj74.2L is offline
post #7 of 8 Old 08-03-2006, 12:28 PM
jeepskate
I'd like to hear more about this one. Could you start a new thread about this or PM me about it (I don't want to hijack this thread)? IIRC the Dakota used the NP-231 which is bolt-on compatible with the Dana 300 assuming the Dak uses 23 splines. I was about to cannibalize a spare 999 to put the lower first gear and the tail section & shaft into a Mopar 904...this sounds like an interesting alternative (like I *really* need to be entertaining changing something else in my build).
post #8 of 8 Old 08-03-2006, 01:22 PM
86cj74.2L
86cj74.2L's Avatar
I must rehook up with my buddy about that. About 2 years ago I mentioned it to him while running into him at a local Napa store. He sounded like (from 2 years ago anyway) that it would be no problem. Expecially if I didn't mind the 231 XFER case. I like the gear drive better myself if given an option between it or a chain drive unit.
I got the idea back then after finding out how much an overdrive unit costs.
When I get more info I start a new thread.
TF999 Troubles chadcarter Jeep CJ Forum 12 05-07-2009 04:58 PM
TF999 ???'s 143hc Jeep CJ Forum 8 04-08-2007 05:14 PM
87 TF999 into a CJ-7 only in a jeep cj Jeep CJ Forum 8 01-10-2007 12:09 PM
5.0 to a tf999 liver156 Jeep CJ Forum 4 05-09-2006 11:54 AM
TF999 hawaiian4x4 Jeep CJ Forum 1 07-12-2002 06:21 AM
