TF999 - JeepForum.com
post #1 of 2 Old 07-11-2002, 12:02 AM Thread Starter
hawaiian4x4
Angry TF999
howzit,got a auto tranny tf999 from a freind of mine,but he told me it needs to be rebuild.Should I spend the money to rebuid this tranny?dont know to much about this tranny.Any advice would be helpful.Much mahalos
hawaiian4x4 is offline
post #2 of 2 Old 07-12-2002, 06:21 AM
Hooch
Post
That depends on what you want to use it for... If you've got a stock 258 l6 or even a 304 V8 it should hold up fine. The TF999 is a medium duty tranny and a rebuild kit isn't very expensive if you intend to do the rebuild yourself.
If however you've got anything bigger than the 304 like a 360, it will probably hold up for quite a while providing the tranny is in a good condition or a rebuilt one, but in this case you'd be better off with a TF727 which is the heavy duty version. This tranny will also fit to the 258, but you would need a 4" lift to clear the front drive shaft from hitting the tranny's oil pan.
Hope this helps.
'83 CJ-7 in Land Rover Country
Hooch is offline
TF999 Troubles chadcarter Jeep CJ Forum 12 05-07-2009 04:58 PM
TF999 ???'s 143hc Jeep CJ Forum 8 04-08-2007 05:14 PM
87 TF999 into a CJ-7 only in a jeep cj Jeep CJ Forum 8 01-10-2007 12:09 PM
Tf999 ckritcoad Jeep CJ Forum 7 08-03-2006 01:22 PM
5.0 to a tf999 liver156 Jeep CJ Forum 4 05-09-2006 11:54 AM
