Testing an MSD 6A and Blaster 3 coil - JeepForum.com
post #1 of 9 Old 03-20-2012, 03:41 PM Thread Starter
twmattox
I was given a friends MSD ignition system. It seems to work very well. However, I have been having an issue with the rig if it has been running a long time (over an hour). It begins with a stumble over 55mph. If I push it and keep driving, eventually it will stall and it takes over an hour to start it again. I am nearly convinced the issue is vapor lock...but, thought I would have the ignition system looked at just in case. Nobody I have called has the ability to "diagnose" an MSD ignition or coil. On a side note, even AutoZone can hook up to a stock ignition and tell me if it has failed...
I have been happy with the ignition system (considerably better than stock); but, where can I have it inspected? I called MSD and they want $85 to inspect it (and another $10 to inspect the coil).
I am open to suggestions...anyone...
twmattox is offline
post #2 of 9 Old 03-20-2012, 04:06 PM
Jack61
1981 CJ7
If you go to MSDs web site there is a test to check for coil output. Next time it shuts off on you it takes just a couple of minutes to do the test.
Jack61 is offline
post #3 of 9 Old 03-20-2012, 08:19 PM Thread Starter
twmattox
Good thinking. The only downside of my ignition upgrade appears to be the inability to test it if I need to...
After talking to MSD, they want $88 to test the module + $10 shipping (plus my shipping costs). That is just to test it...not repair if broken...
twmattox is offline
post #4 of 9 Old 03-20-2012, 08:29 PM
82JeepCJ7
1982 CJ7
Put spark plug in one of the wires. Grab plug with hand. Have some one crank motor. You will know real fast if you have power to the plugs.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #5 of 9 Old 03-20-2012, 08:32 PM
MightyLampshade
1979 CJ7
winning idea!
Originally Posted by Keith
Let's make fun of him for being assaulted by chicken so he can claim emotional distress.
MightyLampshade is offline
post #6 of 9 Old 03-20-2012, 08:38 PM
LimeLite
1978 CJ5
I always thought msd would do a warranty repair for 50.00, I'm kinda surprised to hear it's 88.00 to test.
78 cj-5 4" procrap lift on 35's amc304 "custom" rear bumper/tire carrier combo, rollcage...
Ex-Member of offroad nuts
LimeLite is offline
post #7 of 9 Old 03-20-2012, 08:55 PM
mopar346
Careful boys, he may try it. Only probably is we wont be able to watch.
You do need to determine if it is fuel or fire when it quits, the advantage of it not starting for an hour is it will give you time to test everything. Install a clear fuel filter up near the carb and when it quits look at it, if it is fuel the filter will be fairly empty.
Careful your character's showing
mopar346 is offline
post #8 of 9 Old 03-20-2012, 11:55 PM
86cj74.2L
86cj74.2L's Avatar
Carry a long screw driver and put it in a pulled plug wire and hold it 1/4 inch from engine.
If blue spark it's fuel, if orange spark coil is suspect. If no spark could be MSD or pickup in dizzy.
86cj74.2L is offline
post #9 of 9 Old 03-21-2012, 04:49 AM Thread Starter
twmattox
The rig is down right now (working on coating the inside of the tub and some body stuff). I was hoping to have it running reliably when I get done...I would prefer to have it as a daily driver again; but, it needs to be reliable. I miss driving my Jeep...
twmattox is offline
MSD Blaster II Coil Getting extremely hot and failing. crzdmnky Jeep CJ Forum 9 07-07-2011 07:57 AM
Testing an e-style coil frank c Jeep CJ Forum 1 12-22-2010 09:55 AM
Team Rush and MSD Blaster 2F Coil richeskis Jeep CJ Forum 7 11-28-2010 07:48 AM
MSD blaster 3 coil wireing bobs68bird Jeep CJ Forum 1 10-04-2010 05:02 PM
Replaced factory coil with MSD Blaster 2....Jeep won't start!! lxlmongooselxl Jeep CJ Forum 2 06-19-2008 05:41 PM
