Test drove the CJ7; a few questions... - JeepForum.com
post #1 of 1 Old 10-14-2002, 07:52 AM Thread Starter
IwannaCJ7
Exclamation Test drove the CJ7; a few questions...
Ok, so I test drove the 78 CJ7...
Here's the lowdown...
It's running 32s, not 33s. Funny, one of the front tires is the new BFG Mud Terrain tread desing, the other three are the old one.
It misses the spare, so I could get a new one and use an old one as a spare.
It has the YJ dash/tub/roll bar.
A few rust spots, very few, otherwise good condition.
The interior is bare bones, no carpeting whatsoever. A radical departure from my 4Runner!
Shifting in and out of 4wd is weird, there's like only ¼ of a inch of travel between 2H and 4H, the hubs are manual of course. What T-case is this?
The engine has no PCV valve, supposedly because it's tuned like a racing engine (confirmed by a buddy of mine who's into muscle cars). Thus, it spits a little oil. I always started in 2nd gear (1st is too low), and managed to burn rubber! Twin tailpipes, BTW...
Shocks are RS5000s all around, including the steering stabilizer, new enough to barely be rusted. The body sits on Energy Suspension urethane bushings.
The front end already has two D-ring (shackles), and it looks like holes are drilled to accomodate a winch on the metal plate that sits in between the frame rails.
Now, the questions...
-The tranny has the reverse where the 5th gear normally is (I grinded it everytime I wanted to shift from 2nd to 3rd!); what tranny is this?
-The front axle, prolly a D30, seems to have some positive camber on one side. Is camber adjustable?
-The truck seems to sit crooked, right rear being lower... can a shop re-arch the leafs to make it sit straight?
-The steering rod is just a little over the right front leaf pack, perhaps only around ½ inch. Is this a cause of worry (contact, etc...) or is it normal?
-I'm not sure it's truly lifted (at least until I add the rear add-a-leaves), because there's clearly some rubbing at the rear, since the Ford 9" is wider than the front axle. Will a body lift help? Can I trim the rear sheetmetal to put TJ-style flares? How much work/money is involved in a spring-over conversion?
-Will this truck articulate decently off-road? It rides stiff, so I'm a little worried about wheel travel.
-I could prolly get it for 2600$US. Is it worth it?
Hugo Lafrenière
1999 4Runner SR5 V6 5-speed
Lifted, 32s, other goodies
1997 BMW Z3 2.8, intake-exhaust-chip, other goodies too
IwannaCJ7 is offline
CJ5 rebuild ALMOST done - drove for 1st time - a little mishap DuggerCJ Jeep CJ Forum 8 09-20-2009 10:00 PM
How to test it? Intruder66 Jeep CJ Forum 8 09-03-2009 06:21 PM
just drove my cj7 with the sway bar hooked up lineguyj82 Jeep CJ Forum 3 06-05-2009 08:19 PM
Pulled dads cj out today and drove her around .. *pix* Luke4554 Jeep CJ Forum 8 04-21-2008 03:19 PM
this is only a test 55-willys Jeep CJ Forum 3 12-18-2002 04:08 PM
