which temp sensor location? - JeepForum.com
post #1 of 5 Old 08-08-2009, 06:52 AM Thread Starter
thich
1982 CJ7
i was replacing my t-stat the other day and noticed a second (electric) temp sensor before the t-stat housing neck on the top of the block. the PO had the hole in the neck plugged and a crazy collection of pipe fittings attached to a mechanical temp sensor in a box. should i hook up the mechanical temp sensor at the neck and plug the hole where the electric sensor is, or vice a versa? i have no plan to keep the electric sensor, but i would like to know the best place for my mechanical temp sensor.
the Jeep is an 82 CJ7 with a 302 from a 72 CJ5.
Cheers
thich is offline
post #2 of 5 Old 08-08-2009, 08:16 AM
scottymac62
1979 CJ7
I assumed you meant "304". I put mine where the CTO used to be. Here's a nice picture of the manifold that labels everything. Notice how the EGR CTO port has a mechanical water located there.
http://www.jeepforum.com/forum/f8/76-v8-304-engine-diagram-all-ports-labeled-update-you-wish-455734/
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #3 of 5 Old 08-09-2009, 12:05 AM Thread Starter
thich
1982 CJ7
yeah. 304. i was looking at the 302 that sits in front of my jeep when i typed that.
nice pic, but for some reason it looks a little different than mine. maybe its all those silly vac hoses.
i have sensors for both spots. one at the t-stat housing (spark CTO port) and one at the water temp. sensor port
which spot is better?
Cheers
thich is offline
post #4 of 5 Old 08-09-2009, 01:14 PM
donkey77
1975 CJ5
what kind of fitting goes on the water temp sensor
donkey77 is offline
post #5 of 5 Old 08-09-2009, 10:05 PM Thread Starter
thich
1982 CJ7
its an electrical connection on what looks like a stud in the pic. just one of those wires with a 90˚ rubber boot.
Cheers
thich is offline
Temp Sensor Location 258 EngChase Jeep CJ Forum 3 02-10-2010 05:50 AM
Tempature Sensor location new-jeeper Jeep CJ Forum 7 10-27-2009 03:43 AM
Howell TBI O2 Sensor Location ihavetheWILLto Jeep CJ Forum 3 10-24-2009 09:27 PM
Mech temp sending unit location? Bubba Ray Jeep CJ Forum 15 09-01-2009 07:08 PM
Temp sensor location Bubba Ray Jeep CJ Forum 2 01-01-2006 06:56 PM
