Temp gauge and fuel gauge quit - JeepForum.com
post #1 of 12 Old 08-26-2009, 01:14 PM Thread Starter
Foulplay
1978 CJ7
BOTH gauges quit all at once. One day they both worked, the next day neither of them work. I had to assume that I had a loose wire on the back of the gauges but I can't find anything wrong there. I also assumed that I had blown a fuse, but all fuses are good. Where do I go from here?
South Coast Jeeps
1978 CJ-7 Golden Eagle - 2013 JK Unlimited 3.5" lift
Foulplay is offline
post #2 of 12 Old 08-26-2009, 01:48 PM
RetiredSERE
RetiredSERE's Avatar
1980 CJ7
Check and re-check your grounds.
Shoot, Move, Communicate
Admit to Nothing, Deny Everything, Make Counter Accusations...
I Feel Like a Monkey F***ing a Football..
RetiredSERE is offline
post #3 of 12 Old 08-26-2009, 03:34 PM Thread Starter
Foulplay
1978 CJ7
From what I can tell, the ground is good but I don't really know where all to check. I know that the body of the gauge cluster itself is grounded but where else should I check?
South Coast Jeeps
Foulplay is offline
post #4 of 12 Old 08-26-2009, 03:44 PM
JimNut
Check out these sites from John Strenk. Pretty much all the info you could ever want to learn about the gauges in a CJ.
Basic Troubleshooting for CJ gauges
CJ Speedometer Gauge Quick Test
The new Gauge Page
Build it, Wheel it, Break it, Fix it and Repeat!
JimNut is offline
post #5 of 12 Old 08-26-2009, 07:51 PM
John Strenk
John Strenk's Avatar
1976 CJ5
You will need a test light or a volt meter to continue testing...
John Strenk is offline
post #6 of 12 Old 08-27-2009, 06:05 AM Thread Starter
Foulplay
1978 CJ7
Thanks for your help, I have both and I will try to check this stuff out today around lunch time. Otherwise it will have to wait until tomorrow.
South Coast Jeeps
Foulplay is offline
post #7 of 12 Old 08-28-2009, 03:37 AM
carnuck
1984 J-Series Truck
The temp gauge has a built in voltage regulator (bimetal spring)
carnuck is offline
post #8 of 12 Old 11-08-2012, 11:27 PM
JRRCJ5
Ground
The Speedometer housing grounds to the dash itself throught the four mounting nuts.
JRRCJ5 is offline
post #9 of 12 Old 11-09-2012, 02:48 AM
scottg73
1979 CJ5
I think that's in the fuel gauge. It can cause both gauges to go out at once.
scottg73 is offline
post #10 of 12 Old 11-09-2012, 04:35 AM
John Strenk
1976 CJ5
Yes, it's in the fuel gauge in the OEM gauges.
Some newer gauges just use a resistor to regulate the power going into the gauge. These have a resistor in both the fuel and temp gauge so they can operate seperatly.
post #11 of 12 Old 11-09-2012, 09:33 AM
JRRCJ5
Gauges
This is really not a reply. the trouble I'm have is replaced both gauges. Soon as I put them in the dash they quit working. Checked all grounds good grounds. Any thoughts what to do next. Oh yeah burn up temp gauge have to buy another one. Grounded peg and puff gone.
JRRCJ5 is offline
post #12 of 12 Old 11-09-2012, 10:43 AM
John Strenk
1976 CJ5
So you grounded one of the terminals on the temp gauge and it burned up the temp gauge right away or was the terminal in contact with the case and it burned up after a little while.
Got a picture of the replacement gauges?
TEMP GAUGE, FUEL GAUGE, AND SPEEDO HELP PlEASE cgi2099 Jeep CJ Forum 8 11-03-2009 06:49 PM
where to get new fuel and temp gauge hookntail Jeep CJ Forum 1 10-23-2008 08:29 PM
Speedo, Fuel Gauge and Temp gauge not working KYCJ7 Jeep CJ Forum 1 07-07-2008 01:41 PM
Fuel gauge, temp gauge HEADSPACEXXX Jeep CJ Forum 5 04-03-2008 06:26 AM
Fuel and Oil Gauge quit at the same time! 7DJEEP Jeep CJ Forum 5 03-11-2006 08:59 PM
